speedometer gear
Old May 11, 2007 | 12:25 PM
palazzopl's Avatar
palazzopl
Default speedometer gear
If you change the driven gear on the tranny do you have to change the drive gear also..I have an 81 auto trans, I put a speedo from a 77 and it reads 60 at 45mph ..I was told each tooth on the gear equals 4 mph..
Old May 11, 2007 | 12:39 PM
S489's Avatar
S489
nope
Old May 11, 2007 | 12:48 PM
7T1vette's Avatar
7T1vette
The drive gear is a worm gear that fits over the output shaft of the tranny. You don't change that...only the number of teeth on the driven gear is changed. Speed indication on the speedometer is in proportion to the number of teeth on that gear. The larger the number of teeth on the driven gear, the lower the speed indication.
Old May 11, 2007 | 02:57 PM
palazzopl's Avatar
palazzopl
thanks for the help
To speedometer gear
