Where's the burnout power?
Old May 11, 2007 | 04:42 PM
toupstrio's Avatar
toupstrio
Default Where's the burnout power?
Just installed a fresh 60 over 350 10-1 comp ratio 64cc vortec heads, edelbrock performer intake, holley 600 carb, comp XE268H cams and comp lifters and roller tip rockers. Hooker headers and sidepipes, auto transmission with 3:55 rear end. Car does not do a burnout as I expected any suggestions?
Old May 11, 2007 | 04:50 PM
big_G's Avatar
big_G
Carb, tuning etc. Should be able to smoke 'em up.
Old May 11, 2007 | 04:53 PM
spedaleden's Avatar
spedaleden
What year is the vette, not that it matters. Are you sure you know how to do a burn out? I would think if everything is working right you should be able to leave some nice rubber on the street. I would of went with a 750 holly but the 600 should do it. When you run it does it have a lot of torq?
Old May 11, 2007 | 05:07 PM
GTR1999's Avatar
GTR1999
Here is a result of a 370 hp 4 spd and a lot of 200' burnouts. Be careful of what you wish for! LOL
rihwoods's Avatar
rihwoods
Slush box gremlims....
Rich
Old May 11, 2007 | 05:10 PM
enkeivette's Avatar
enkeivette
Inflate the tires some more.
Old May 11, 2007 | 05:11 PM
toupstrio's Avatar
toupstrio
Its a 79 seems to have a lot of torque the front end will lift upon acceleration. I put a 750 on it and it had some fuel leakage problems Holly 750 double pumper I have all the parts to repair it now, it seems to run fine with the 600 on it just thoought it would have more low end power when everything I had for the engine was 0-5500 rpm range.
Old May 11, 2007 | 05:12 PM
toupstrio's Avatar
toupstrio
I would settle for a 100' burnout.
Old May 11, 2007 | 05:19 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I'm guessing and automatic, do you know how to do a brake stand ?
If it's a 4 speed you got problems, my grandmother's 6 cylinder '63 Rambler station wagon with only 5 cylinders working would lay down a half decent patch
Old May 11, 2007 | 05:23 PM
toupstrio's Avatar
toupstrio
Yes its an automatic. Well the rest of the story is the brakes were faulty and you know i wanted the engine fixed before the brakes. Who needs to stop So i put 4 new calipers on last week and my motive pressure bleeder just came in today so I can bleed them without the wifes help Then I will take it back out for a test run.
Old May 11, 2007 | 06:34 PM
7T1vette's Avatar
7T1vette
If the tranny is a stock unit, you may not be able to get the revs you need at stall before you release the brake...you may be too low in the torque band. You also didn't mention the width/type of tires you had on the back end. Very wide, sticky tires would make it more difficult to break loose.
Old May 11, 2007 | 06:42 PM
ajrothm's Avatar
ajrothm
You need a stall speed converter in that auto, thats why... Especially with a cam that is 224/230 @ .050. Stick a 3000 stall in it and you will be looking for drag radials just to get it to hook up.
Old May 11, 2007 | 06:48 PM
toupstrio's Avatar
toupstrio
I might have to get a stall convertor and try it out.
Old May 11, 2007 | 06:55 PM
ajrothm's Avatar
ajrothm
The best bang for the buck stall is a HUGHES GM30. Its a 3000 rpm stall...or at least thats what its rated to. They will all stall differently according to the powerband of the the motor.
That will wake you up BIG TIME.
Old May 11, 2007 | 07:10 PM
427-390's Avatar
427-390
I took out my BB a/t (TH 350) for a shakedown cruise a couple of days ago. I put the car in 1 (low), and from a standing start, without using the brake, stabbed the gas and got a good "chirp'. If the car is running right and set up right, it should be able to lay down rubber no prob.
Old May 11, 2007 | 07:11 PM
toupstrio's Avatar
toupstrio
Thanks for the info.
Old May 11, 2007 | 07:53 PM
GTR1999's Avatar
GTR1999
What are you trying to do? Catch a chirp in 2nd gear or lite up the tires launching it?
I have a plain old B&M holeshot 2000 stall in my 72 with B&M retrofitTH400 and 336 gears. The 350 is about 325 hp. I can hold the brake to lite them up and launch it no problem, haven't really held it in 1st to chirp into 2nd gear.
To Where's the burnout power?
Old May 11, 2007 | 08:50 PM
toupstrio's Avatar
toupstrio
You know the the funny thing is really don't know I haven't tried a burnout usng the brakes I did chirp at second I just thought it would lay rubber on take off more.
Old May 11, 2007 | 09:07 PM
spedaleden's Avatar
spedaleden
I had the same problem with mine and it's a 4 speed. I had a GM crate motor GM rated it at 400 HP at the crank with stock 4 speed and 2.72 rear end gear. It spun the tires but not like I wanted. I put a keisler 5 speed and changed the rear end gear to a 3.55 and you can spin without trying. Now I just got to get rid of the whine from the rear end and everything will be good.
Old May 11, 2007 | 09:13 PM
toupstrio's Avatar
toupstrio
I have a 78 that I might take the 4 speed out and change over everyting, instead of sticking wth the auto.
