Tech Tip-- for your safety
Old May 12, 2007 | 04:44 PM
TimAT's Avatar
TimAT
Default Tech Tip-- for your safety
If you're fixing any wires around the HEI distributor and soldering them (the correct way), and you use a WELLER soldering gun, PLEASE make sure the key is OFF! The magnetic field around that soldering gun will cause the distributor to fire. If the key is on, and you're leaning over the fan/ alternator, if the engine is in the correct position to fire a cylinder, it could start. and leaning or laying on the fan will hurt..
Old May 12, 2007 | 05:14 PM
Kilroy1024's Avatar
Kilroy1024
Is this something you personally experienced, or heard on the net?
The magnetic field around a Weller soldering iron tip is very weak and I cant see how it could possibly couple enough energy into the secondary of the igniton coil to create a spark.
Sounds like an urban legend.
Old May 12, 2007 | 06:36 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
He is probably talking about the ignition trigger/ hall effect switch.
Old May 12, 2007 | 07:12 PM
Kilroy1024's Avatar
Kilroy1024
The pick-up sensor is a coil under the distributor about a mm from the magnet.
The soldering iron would have to be pretty close to that pick-up to have any effect.
Is it possible the soldering iron shorted something to ground which triggered the ignition?
The basic tip is good: Turn power off when soldering.
You could do something out that causes the engine to turn over.
Old May 12, 2007 | 08:39 PM
rcread's Avatar
rcread
I always disconnect the battery when I'm under the hood. Seems like a sure fire way to assure nothing goofy happens.
Old May 12, 2007 | 09:33 PM
jdmick's Avatar
jdmick
This is something that wouldn't have occurred to me in a million years. I too would like to see this demonstrated.
Old May 12, 2007 | 10:02 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
Wel I could see it making a spark, IF the ignition was on. But I gotta spin my engine pretty god for it to start...
Old May 13, 2007 | 12:20 AM
TimAT's Avatar
TimAT
NExt time you've got an HEI out on the bench, clamp the body in a vise, and hook it up- 12V and a ground. Then wave the soldering gun- Not an iron over the top of it. It will fire. Saw this happen at the GM training center in KC.
Old May 13, 2007 | 02:50 AM
greg454's Avatar
greg454
old weller soldering guns (guns--not irons) produce strong magnetic fields. I use to use one to degauss old tv's and monitors.
Old May 13, 2007 | 11:37 AM
supercalvin's Avatar
supercalvin
Or working inside the dash.
To Tech Tip-- for your safety
