Exteremly Hard To Start.
It turns over without firing off for the longest time. Then I hear a small dull knock. It’s not like a normal engine knock that is the sound of doom for an engine. I know what that sounds like and it isn’t that.
Then it will try to barely fire off once. Then nothing. Then it will try to fire off again. Then it will backfire through the carb. I saw flames shoot an inch to two inches out of the carb! I was glad I removed the air filter! Then nothing, it fired off once. Then it superted for two more tries, then it fired off and was good.
I shut it off and then I started it right up with just a turn of the key. I did this twice.
Yesterday it took me awhile to get it started. Same as above. And once I got it started I could hear a vacuum leak while the engine was running. A couple of times when I pressed the accelerator linkage down I could hear air being shot into the carb in place of gas. After about 2 minutes of idling it cleared up and ran just fine, still with the vacuum leak.
Anybody know any possible culprits that could cause this and how to fix it?
No offense meant but a lot of young guys now a days have never driven a car with a carburetor before. Carburetors and fuel injection start differently.
BigBlockk
Later.....
I recently rebuilt the carb and flooded the carb when I put it back on and went to start it up. It's a stock '74 Q-jet, without a choke plate or linkage. I don't know what happened to it, other than one word. BUBBA!
I'll check the vacuum lines tomorrow and see what that does.
Bigblock, I am not asking about the choke plate, I know that this isn't the problem. It ran without it, it's going to run without again just as easy.
I was under the impression that the choke system was there to make the engine easier to start when it is cold. I've only worked on cars for 36 years so I may be wrong about that.
BigBlockk
Later.....
You'll need to remove it to check. The ports on the bottom should be closed.
Now, BigBlock, I have had the car since February, I am currently living in North Carolina. It snowed two weeks before I got the car. The weather temps remained in the 30 and 40s when I got the car now its in the 50s, in the morning. The car has been missing the choke since I owned it and it's just now acting up. I think it would have acted up in those cold mornings when I first had it then now when the temp is about double. What do you think?
The car will probably start easier with a choke plate but the fact remains that I use the car as a daily driver, every single day and it is just now being hard to start. So I highly doubt it is because of the way it has been for months.
New problem means something else broke, right?
Oh and the last few times i have started it, it was in the middle of the day! When its anywhere from 75* to 95* I don't think the engine is cold.
I am not trying to be disrespectful but it is irritating. I know I need to put a choke on it, for it run 'properly' and I also know it will run without a choke. My logic tells me it might be the choke with the combination of something new. Or some new problem by itself, and I am trying to figure out what that new something is. I KNOW THE CHOKE NEEDS TO BE FIXED.
Sorry I am just getting frustrated. I would rather have straight answers/advice/tips than sarcasm. Yeah I may be young in years but that doesn't mean I can't read something the first time and understand it.
Have a good day sir.
Thank you for the tips gentlemen. I will see if it fixes anything.
I haven't turned the distributor.
I believe it has a vacuum advance. It has a vacuum line that hooks up to the distributor at its base.
I replaced the plugs, and distributor cap and rotor, it started up fine after that and then the next day was when all these problems started happening. I will triple check the wires but I highly doubt I have a wire out of place. Once it starts up, it runs like just fine.
It has points.
I just tried starting it.
I noticed that I could hear a sucking sound over the engine as it was turning over and that when I pressed the gas pedal the sucking sound went away. Is this normal?
All the spark plug wires are in their correct spot. The PCV valve is still good. And I didn't see any visible holes in any of the vacuum lines. One line that comes out of the front of the carb is plugged with a screw. I don't see it's other half but their is a vacuum operated device that is bolted to the intake manifold that has no vacuum hose hooked up to it.
