Exhaust leak or other problem
Listen to valve covers with a long wood dowel or screwdriver...if anything is there,you will hear it..
For exhaust leak, you should be able to pin point it carefully by running your hand about 3" away from manifold/pipes and feel exhaust escaping...doubt gaskets swell enough to stop it...could be at flange to pipe(s) at manifold....???
You may just have a lifter pumping up slow..???
Rich
Rich
If it is a lifter pumping up slowly..is this something I should address? Can it harm my valvetrain? What would the fix be if this is the problem?
I appreciate the information.
The reason I think it may be a exhaust leak is when I had my top end redone at a local shop last fall the guy had a hard time getting the headers to seal properly. I had to take it back once with an obvious exhaust leak. He then said he had to use some thicker copper gaskets and he put a little high temp sealant to help get them to seal properly. I'm thinking this problem may be creeping up again.
Not real sure on lifter...if you find a noisy one,it could just be an adjustment hopefully...check it out first..be sure to probe/listen every 4" or so over length of valve covers...
Rich
