Now... Transmission Trouble?????
well - then why do i keep having these little farts? so i pick it up from getting the alternater and battery replaced and as soon as i pull outta the shop...
! it's not going into 2nd gear (it's a "turbo-hydra automatic"). so i bring it back like, WTF????they get it up on a lift and notice that this (forgive me here - i totally don't have the terminology)... well, this little metal pipe/hose which was connected to it's receptacle with a short (2 inch) rubber connector tube had come loose.
they replaced the connector tube with a new one and zip tied it. they totally couldn't give me a good explanation of 1) what this thing was, and 2) if this would need further attention.
when i brought it in it was running PERFECT. how the hell did this happen if they weren't even NEAR the transmission to fix the alternator and didn't even jack the car up to fix the alternator? but how could this be just blatant coincidence that it decided to come loose while in their shop?
either way, i don't really care about that part bc they didn't charge me to fix that or anything....
more importantly... what WAS that and do i need to give it further attention???
Thats a hint, Lots of "Mechanics" are out to do you the dirty where the sun don't shine
Get yourself a rental space/garage and learn some stuff
NOT!!!
1) Find out what your neighborhood mechanic likes and buy him a lot of it. Booze, hookers, fine food. Whatever.
2) Get used to little incidents like this. Your car is 36 years old. Regardless of how well it was restored (and it looks from the pics like it was very well restored) there are parts on it that were born before you were. Stupid little parts like the modulator valve hose will fall off, come loose or break all the time. Take it for a spin down Lombard and see if it falls off again. At least now you can fix it yourself if you want to.
You're right about the cost of space though. I live in the tri-valley and still pay $250 for my storage for mine. Fixing it in the street probably isn't such a good idea either.
If you were single and a had an opportunity to put your hands all over a hot chick wouldn't you?
i'll look into another mechanic. cheers
gotta go to mother's day brunch with the in-laws... UGH!!!!
