Engine Help
Old Oct 21, 2001 | 01:46 PM
467-Ratman's Avatar
467-Ratman
Default Engine Help
My 71 coupe has the original 350 4 bolt main block, I am going to rebuild it with a 400 crank to make it a 383. I want to go with Dart Iron eagle heads, with the 9.6-1 compression. I was wondering what cam I should use? I have a Muncie M-21 4 speed with 3:70 gears. I want strong mid range HP, don't really care about spinning to 7000 rpm. I have a GM aluminum dual plane intake with a Holley 780 dual feed carb. Thanks for info!
