Door adjustment?
Old May 13, 2007 | 09:38 PM
glo's Avatar
glo
Default Door adjustment?
Having hard time adjusting door to be even with body door closes to far?What am I doing wrong?
Thanks for any sugestions
Old May 13, 2007 | 09:59 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Wow. I wish I had your problems. Mine is just the opposite and does not close far enough. One thing I did learn was that if you put the stricker too much in board, the door latch will not click the second time and the door will stick way out. So I had to go a different route and pull the stricker outwards. This allowed the latch to click the second time and the door to close tighter and closer to the body lines. I don't know if this will add any help but maybe using the same logic might work for you too.
Where is your stricker located in to the opening in the hole? More inboard or more outboard?
Old May 14, 2007 | 11:50 AM
Belgian1979vette's Avatar
Belgian1979vette
You can mount shims under the door hinges to move the door out, the backside is adjusted with the door striker.
There is a lott of fiddling around when adjusting, and even then sometimes the don't even come close.
Old May 14, 2007 | 06:35 PM
JackDidley's Avatar
JackDidley
You may need to remove the plastic kick panel to get at the door hinge adjustment. Its been too long since I have done it to describe how, but it was well worth the effort on my old 75. It put an end to water leaks.
To Door adjustment?
