power windows on a 72
Old May 14, 2007 | 09:22 AM
fuelie65's Avatar
fuelie65
Default power windows on a 72
Hi Gang...
My power windows just stopped working ( both of them )
Where do I go first ? The relay under the console ??
Thank you...
Old May 14, 2007 | 09:31 AM
Binnie77's Avatar
Binnie77
Originally Posted by fuelie65
Hi Gang...
Thank you...
With both of them dead I think you are on the right track...relay sounds dead or getting no feed.
Old May 14, 2007 | 02:37 PM
7T1vette's Avatar
7T1vette
Check fuses first, then check out the relay.
Old May 14, 2007 | 07:39 PM
shafrs3's Avatar
shafrs3
Check that you have power through the circuit breaker under the hood first, it's much easier to get to and you won't feel like a dummy tearing apart the console only to find it was the culprit all along.
Old May 14, 2007 | 09:14 PM
coinwasher's Avatar
coinwasher
Check power to the brown wire plugged into your accesory jack on the fuse panel.
To power windows on a 72
