floor pan & sill needs help
Old May 16, 2007 | 05:04 PM
73C34me's Avatar
73C34me
Default floor pan & sill needs help
I have a 73 with the driverside floor pan (lateral area) & sill area in baaad shape. I have looked around & can't find replacement pieces. I can't be the only one in this boat!
When I lifted the body off, the rocker channel was so bad it collapsed, cracking the sill & outer floor in many pieces.
Obviously glassing it up is an option, but it is going to be a major job to do this. Ideas?
Old May 16, 2007 | 11:13 PM
Artsvette73's Avatar
Artsvette73
I would repair the rocker channel first then work on the floor and sill. You should be able to glass it all back.
