Rev limiter
Old May 17, 2007 | 10:18 AM
bashcraft's Avatar
bashcraft
Default Rev limiter
My engine builder suggested that I get a rev limiter. I guess he doesn't think that I can shift very well. Anyway, what is a good one for use with an HEI?
Old May 17, 2007 | 10:51 AM
TimAT's Avatar
TimAT
He's not picking on you, he's protecting himself from an unhappy customer. If it over rev's and something breaks, you'll be going back unhappy. I just got a Summit branded CD ignition with rev limiter- Instruction sheet shows HEI and it was $159.
Old May 17, 2007 | 10:59 AM
gkull's Avatar
gkull
Get the Crane Cams Multi Spark unit. It is a digital sequential misfire. The rpm is set by a dial and not some phony plug in resisters that might be off a few 100 rpm.
I have so much faith in mine that I drive it into the rev limiter with my foot on the floor into the braking zones
Old May 17, 2007 | 11:11 AM
Bangkok Dean's Avatar
Bangkok Dean
great do you have a link
bashcraft's Avatar
bashcraft
Yes, he is picking on me, and protecting himself. He's also my brother and he knows how I drove the car when it had the small block in it.
Old May 17, 2007 | 12:01 PM
gkull's Avatar
gkull
This is what I have. The also have the single stage lower priced versions.
http://www.cranecams.com/index.php?s...lvl=5&prt=1972
Old May 17, 2007 | 10:34 PM
Bangkok Dean
thanks
Old May 18, 2007 | 12:27 AM
Restorod '79's Avatar
Restorod '79
I put a nice kit on my dist. made by MSD. Cap, rotor, coil, cover, and a rev limiter (manual adjustable) built into the module. Got it from Summit-- Part MSD-8501 for @ 180.00.
I'll never get used to hitting a rev limiter. Don't do it often, but it scares the hell out of me!!
Old May 18, 2007 | 08:09 AM
bashcraft's Avatar
bashcraft
Looks like a nice kit, but I wish I could buy just the module. My distributor is new and only has an hour of run time on it.
One thing mentioned in the instructions for this kit has me a little confused.
"TRACTION CONTROL DETECTION
The Digital HEI Module has a unique Traction Control Detection (TCD) code built into its
microprocessor. This technology carefully monitors and examines the signals of the ignition. If the
TCD determines that any signal has been modified in any way, the ignition will be put into a low
rpm rev limit mode to immediately slow the car. Before this rev limit is imposed, the TCD goes
through a list of cycles and checks to qualify that the trigger has been modified. There is no way to
bypass or deactivate the TCD circuitry."
Is this good or bad?
Old May 18, 2007 | 09:45 AM
Gordonm's Avatar
Gordonm
I am running the single stage Crane HI6 as Gkull suggests above. I have bounced it off the limiter many times and it works great. I tried it at 4000 rpm when it was new and just left my foot on the floor to see if it would gain any rpm and it stayed right at 4000 rpm. Still use it with my MSD dist.
Old May 18, 2007 | 11:11 AM
Restorod '79
This is news to me--- I didn't see that in myinstructions, and it may be a new feature. As to bad or good-- I think it would be good for your engine, and your fenders, if you had a slow down feature. It might prevent you from doing some mad drifting or burnouts, but my car won't do either.
Thanks for pointing that out- I'm curious and now I'm going to pull my directios out and double check.
Ok- I DO have that feature, but to my knowledge have never activated it. I'm going to call MSD tech and see what's up and how this works. I don't know how the module could detect a traction issue without ABS sensors. sensors around the drive train, differential, etc. , like the new cars have???????
OK- Spoke with MSD- The TCD is built in to detect any kind of traction control device in use on a car. This is to assure that there's no CHEATING going on in some racing applications. If it detects some traction devices, usually a timing/wheel speed sensor, it will slow an engine.
When used on a street car, or older car like ours, it will have no affect.
You're not running a circle track car with traction control, are you??
Old May 18, 2007 | 11:19 AM
bashcraft's Avatar
bashcraft
I saw it here.
http://static.summitracing.com/globa...1_frm27072.pdf
Old May 18, 2007 | 11:36 AM
Restorod '79
Got it! (See above post )
Also, if your dist. is new and you just want the control, I agree with Gkull, get the Crane or the MSD 6AL. These are the industry standard, used in every race car built across the country, and every hot-rod I've seen.
Old May 18, 2007 | 01:54 PM
bashcraft's Avatar
bashcraft
Thanks everyone, looks like one of these 2 are my best choice.
Old May 18, 2007 | 05:37 PM
gkull's Avatar
gkull
Crane is digital. MSD also has their digital line. 6AL is not a good item.
Old May 19, 2007 | 12:07 PM
ShinodaVette's Avatar
ShinodaVette
Why?
Old May 19, 2007 | 12:23 PM
gbak's Avatar
gbak
Intresting thread!
Hope it's ok if I hijack it.....
I'm also looking for a rev limiter.
Today I have a MSD 6A (without rev limiter) but with my new engine I really need something stopping me from rev over 7000 rpm.
Is the Crane HI6 compatible with my dist MSD MSD-8458 (nearly the same as MSD-8571) and a regular coil?
I have also looked at Accel 300+ and Holley Annihilator 75.
Is there any differens between the boxes or are they all the same?
To Rev limiter
Old May 19, 2007 | 12:33 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
The 6 AL is prone to failure. I bought the 6 ALN. The N is the Nascar vesion. The internals are totally encased in a clear gel and it has vibration isolators built in and on the mounts. It isolates the internals from excessive heat, vibration and shock which kills the 6 AL. I ran mine for 2 years with no issues and it's going back in the new build. Pretty nice option and priced not much different than the 6 AL.
Old May 19, 2007 | 09:14 PM
strokervette's Avatar
strokervette
I got the MSD Digital 6 on my car.
http://www.msdignition.com/ignition_18_6520.htm
Old May 20, 2007 | 10:21 AM
gkull's Avatar
gkull
Originally Posted by gbak
Intresting thread!
The Crane has directions with it for several different setups. I ran mine with Mallory and now MSD e-curve.
MSD 6AL....... are bad. It's a 20+ year old bad design of random misfire. It is anolog, power sucking, prone to heat failure, can leave you stranded, phoney plugin rpm limiters. Any one that buys one.....well I won't go into that
