what is this?
Old May 17, 2007 | 04:53 PM
74batmobile's Avatar
74batmobile
Default what is this?
just wonder what these 2 things are.....
thanks
Old May 17, 2007 | 05:04 PM
Durango_Boy's Avatar
Durango_Boy
I think picture one is of the A/C dryer, and the bottom pic's arrow seems to be pointing at a wiring harness.
Old May 17, 2007 | 05:17 PM
redwingvette's Avatar
redwingvette
Top picture is the VIR valve for the AC. If you are not pointing at the wire harness then are you pointing at the AC condenser box?
Old May 17, 2007 | 05:19 PM
SIXFOOTER's Avatar
SIXFOOTER
Yep, the first one is the Dryer for the AC system, second is the wire harness just below the resistor pack for the fan speed control
Old May 17, 2007 | 05:31 PM
74batmobile
do i need either if i dont have an ac? i dont plan on puttin one in .....
Old May 17, 2007 | 05:32 PM
dgruenke's Avatar
dgruenke
Yep, the first is the VIR (dryer), and the second (if it is not the wiring harness) is the evaporator core housing.
I believe the condensor is actually in front of the radiator.
Edit: If you don't have a/c, you don't need either of these. If your system has been open to the air, then your VIR is no good anyway.
Old May 17, 2007 | 06:00 PM
74batmobile
what do u mean open to air? i dont have the condencer in front of the radiator.....but i still have all that stuff....
Old May 17, 2007 | 06:02 PM
Durango_Boy
Open air means air in the system. If someone had removed anything and the inside pressure was allowed to mix with outside air then the dryer is junk.
Old May 17, 2007 | 06:07 PM
74batmobile
oh ok.... do u guys think i shold just yank it out? i think air is probably in there cause most of the hose are disconected.....and with the wireing harnest.....if its not pulg in anything bad will happen
Old May 17, 2007 | 06:12 PM
Durango_Boy
I just pulled the A/C box out of my '77 and it was NOT easy. I would suggest leaving it in there unless you plan on taking the motor out. It was a pain in the butt with the motor in the car.
Old May 17, 2007 | 06:16 PM
74batmobile
is it welded/bolted to the firewall? thanks DB for the info
Old May 17, 2007 | 06:18 PM
Durango_Boy
There are two long screws from the inside that hold to the bottom of the box, and there are 4? bolts holding it in from the outside. The A/C dryer being attached is the biggest problem as you can't rotate the box to slide it out without lodging against the wheel well of engine.
I tried separating the box in half by taking out all those screws but the bottom is riveted to the other half. I had to use a long flat screw driver to break the rivets.
This may be different for your car. Mine's a '77.
Old May 17, 2007 | 06:22 PM
74batmobile
and thats for the AC box right? how bout the A/C dryer in the first pic?
Old May 17, 2007 | 06:23 PM
Durango_Boy
That's attached tot eh box via some big coolant tubes. You will probably not be able to separate them with the box in the car and that's why I pulled the box with the dryer when I took mine out.
If you get the dryer off, maybe cutting the tubes, you will have a lot more room.
Old May 17, 2007 | 08:29 PM
redwingvette
You cqan remove the VIR/dryer but it is a real pain. I have had to replace mine a couple of times. When i first got the car back in 93 it did not work so I pulled everything and replaced it all. The VIR's are a bad design and if your lucky you can get a few years out of one. Plus they only work with the old R12 which is expensive. If I had it to do over again I would upgrade to a newer system that is designed for R134. That may happen anyway if it craps out again.
Old May 17, 2007 | 10:06 PM
74batmobile
well i dont plan on using an ac system in this car...the condenser in front of the radiator is gone and i really dont want to have the extra weight...im already draging on low hp (l48) so what ever weight i can get rid of is good for me =) Oh this might be random...but what do u guys do for loose wireing? i got a few wires that are diconnected....and jsut want to cap them off.
Old May 18, 2007 | 10:57 AM
dgruenke's Avatar
dgruenke
GM certainly did not make them easy to access.
On the point of removing your evaporator from the box, I don't believe the evaporator is very heavy. For the trouble of removing it, I would just leave it in. Also, if you, or any future owner, ever wants to put A/C back on, parts can get pretty expensive. So, make sure you keep all of the parts. If you can get to the VIR, it won't hurt to remove it if you want a cleaner looking engine compartment.
Now, the compressor is another story. That thing is not light.
To what is this?
