Blinker Light
Old May 19, 2007 | 12:04 AM
jackwhyit's Avatar
jackwhyit
3rd Gear
Default Blinker Light
Hi guys, I am totally new to this, I have a 77 L48 that I am doing a mild resto on, well I bought it from a lady who stripped the interior completely, so I have been slowly putting it back together. I put the spedo and tach in and there is a blinker light on the tach that stays on, does anyone know how to fix this or what is causing it? Thanks
Old May 19, 2007 | 02:24 AM
Z-man's Avatar
Z-man
A couple of guesses:
Does it stay on when you try to signal? If so, one of the turn signal bulbs is burned out on that side.
If it goes on when you turn on the key, maybe the blinker itself is stuck on and you need to replace it.
Old May 19, 2007 | 02:39 AM
onaqwst's Avatar
onaqwst
you have low blinker fluid....
jk
might be the wrong bulb...... some bulbs are 3 prong and other are just the standard 2......
b
Old May 19, 2007 | 03:18 AM
grybdn's Avatar
grybdn
i think you need to shut off your high beams (headlight)
To Blinker Light
