Serpentine conversion head-scratcher
Old May 20, 2007 | 03:50 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
OK, it looks like the L98 pump is too short...AND it has a larger center shaft than the hole in my pulley. This is freakin' confusing...I'm just going to see if O'Reilly has one of those "T" fittings.
Old May 20, 2007 | 04:29 PM
mrvette's Avatar
mrvette
Originally Posted by Chuck-75
I used a serp. belt system from gm, (the one you can get the complete kit from summit or anywhere else?, and the water pump is long style . you can go to any GM dealler and get one for this set up and it does have the heater hose outlet in the top .........................
OH, yeh, I have seen those with plugs in them, but never with a fitting/hose connected....mine has a 1/2 npt pipe out the pass side....directly 90* off the top fitting, which is a 3/8 NPT boss for something I forget.....I used to use it for the extra support on my old air cleaner assy box/shield off the TPI....
I remember taking B body Poncho front accessories to build many a A body Poncho....they fit....and were so much easier to work on....
so far there are about 8? SBC water pumps.....discounting the aluminum variations....
freeking stupid.....and they wonder why they are broke....
Old May 20, 2007 | 07:44 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I found a truck pump that's going to work. Apparently there were two variants for the 87-94 pickups...one with the fitting and one without. All is well now.
