My Driver's side brake is hanging up(not releasing). I have flushed the system with new fluid, and bled the brakes. I thought it was the caliper, so I bought a new one...its still not releasing. The passenger brake caliper is.
Is this a sign of a bad Master Cylinder or could it be something else?
I have not experienced this personally, but others have had collapsed rubber lines that have prevented the brake from releasing. If your lines are old they might need replacing.
Rick B.
That's more than likely the problem, the inner liner of the hose breaks away and acts like a check valve....
