Heads...
Old May 19, 2007 | 09:25 PM
jerrylee's Avatar
jerrylee
Default Heads...
Hey guys what's the difference in heads between aluminum n cast besides weight....n is it true that the iron heads can take more of a beating....Thanx...Jerrylee///
Old May 19, 2007 | 11:31 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Besides the 75+ lbs. weight savings (alone worth the difference), the aluminum heads can usually be repaired in the event of a disaster, unlike iron, and allow higher compression ratios. If cost is a factor, that is the downside.
Old May 20, 2007 | 06:42 AM
llew71BB's Avatar
llew71BB
May I ask why it is that you can run higher compression with alluminium, how does the material affect this?
Old May 20, 2007 | 07:06 AM
Little Mouse's Avatar
Little Mouse
Aluminium dissipates heat at a fast rate, iron does not.
Old May 20, 2007 | 08:24 AM
mrvette's Avatar
mrvette
All I can say is.....switching directly from Iron 993? cast heads that had been smoothed over, but still had 194/15x valves, to a set of 113 L98 alumium heads made a large improvement in performance....same valves, with no port work at all, they were declared close enough by me...
I think the increased compression on the heads goes well with the TPIS ZZ9 cam in there for a long time now....
Old May 20, 2007 | 01:41 PM
Ironcross's Avatar
Ironcross
The actual scale weight on a BB engine is a 70 lb. savings from iron to aluminum. On SB`s I dont know. Performance between the two is the same, the only advantage is the weight.
To Heads...
