brodix heads in
Subscribe
May 21, 2007 | 08:56 AM
Quote: Hey, I recognize those Brodix Heads, I run the IK200's on my 383. Good choice Man!
Also recognice the 1st Cav. Headgear too
Regards
11th ACR my man
BLACKHORSE!!!!!
ALLONS!!!!!!
Reply 0
May 21, 2007 | 08:59 AM
Quote: Nice work! Did you re-use the old pushrods?
For now yes.... they were all in good shape (and I kept them with the lifters that started with), though I will keep an eye out when i start it for geometry issues, The primary difference between the original casts and th new is that the new uses pushrod guides, while the casts had small pass through holes. I'm thinking ill be OK but well see for sure
Reply 0
May 21, 2007 | 09:12 AM
Quote: For now yes.... they were all in good shape (and I kept them with the lifters that started with), though I will keep an eye out when i start it for geometry issues, The primary difference between the original casts and th new is that the new uses pushrod guides, while the casts had small pass through holes. I'm thinking ill be OK but well see for sure
Do some research, but I believe they wan't you to run hardened pushrods with guide plates.
Reply 0
May 21, 2007 | 09:14 AM
Quote: 11th ACR my man
BLACKHORSE!!!!!
ALLONS!!!!!!
Reply 0
May 21, 2007 | 09:25 AM
Quote: Do some research, but I believe they wan't you to run hardened pushrods with guide plates.
Good point, and it makes sense, Ill give brodix a call later today
Reply 0
May 21, 2007 | 10:51 AM
, definitly. Running self aligning rocker arms would be the only reason not to use Hardened Pushrods and the guideplates.
Reply 0
May 21, 2007 | 01:21 PM
You defently need hardened 5/16 pushrods, those brodix heads look as tight as my dart"s. i could tell by the angle on your rockers. Comp cams website has instruction for checking pushrod length, the 180 darts used stock length but you need to check before you order. Also take a flashlight and shine it up through the bottom of the head and make sure you have pushrod clearence where they go through the head, dont need much but you do need some. It"s ok if they rub on the guideplates but not on the alum head, on those rockers that look not centered on the valve make sure the pushrod is not binding in the guideplate. If they are you may need to grind the top edge of one side and the bottom edge of the other side where the pushrod goes through the guideplate to free em up.
Reply 0
May 21, 2007 | 02:56 PM
If you have the room you can go with the .75" high square to spread bore adapter.
Scouts Out!!
Reply 0
Explore
May 21, 2007 | 07:16 PM
Quote: You defently need hardened 5/16 pushrods, those brodix heads look as tight as my dart"s. i could tell by the angle on your rockers. Comp cams website has instruction for checking pushrod length, the 180 darts used stock length but you need to check before you order. Also take a flashlight and shine it up through the bottom of the head and make sure you have pushrod clearence where they go through the head, dont need much but you do need some. It"s ok if they rub on the guideplates but not on the alum head, on those rockers that look not centered on the valve make sure the pushrod is not binding in the guideplate. If they are you may need to grind the top edge of one side and the bottom edge of the other side where the pushrod goes through the guideplate to free em up.
there wa no binding, and the brodix head have a large gap where the pushrods go through, I learn more when i turn it over, but ill order the hrdened pushrods just to be safe...
thnaks for the heads up
tim
Reply 0
May 21, 2007 | 07:17 PM
Quote: If you have the room you can go with the .75" high square to spread bore adapter.
Scouts Out!!
never heard of such a thing, who sell it ?
Reply 0
May 21, 2007 | 07:24 PM
Update from today
yea baby
just need the f bracket for the alt, pop in the distributor and the wire looms, and im makin noise
Reply 0
May 21, 2007 | 08:03 PM
Sweets, love the new additions
Love those pipes!!!
nice head....ers
and I want that hat!!!
Laurie
Can't wait to hear it on the run
Reply 0
May 22, 2007 | 08:30 AM
  #33
Quote: Sweets, love the new additions
Love those pipes!!!
nice head....ers
Laurie
Thanks L cant wait myself, these actually went in quite easily
and I earned my hat in the Fulda Gap in the FDR, spurs too
Reply 0
May 22, 2007 | 10:46 AM
  #34
Quote: never heard of such a thing, who sell it ?
http://store.summitracing.com/egnsea...=KeywordSearch
http://store.summitracing.com/partde...5&autoview=sku
I haven't checked the other vendors but I'm sure they have them as well.
Reply 0
May 22, 2007 | 11:31 AM
  #35
well Ill be.......
Thanks, you may have just solved my problem, I like that last one the best
Good Looking Out
Tim
Reply 0
May 22, 2007 | 03:32 PM
  #36
You are welcome.
Happy to help a fellow Cav Trooper
I wouldn't know what to do without this forum.
That Mr. Gasket set looks to be much more complete and a WHOLE lot cheaper.
I looked into this a few weeks ago as I was researching a intake upgrade and wanted to keep the Larsified q-jet.
But now am looking at the vortex setup from SDPC.
Still haven't pulled the trigger on anything yet.
Reply 0
May 22, 2007 | 07:12 PM
  #37
Quote: Thanks L cant wait myself, these actually went in quite easily
Keep it safe!! *warning* Don't bring it with you on the run!!"
Might find a new home
I don't use spurs on Buzz so they are safe!!
Just know I'm plotting
Reply 0
May 23, 2007 | 06:50 AM
  #38
Quote: Keep it safe!! *warning* Don't bring it with you on the run!!"
Plots and plans Pots and pans Double LL, You aint gettin my stetson baby, Though I might let you wear it
Reply 0
May 23, 2007 | 06:52 AM
  #39
Plus I like the open plenum design
Where were you? Div Cav or Regimental
Reply 0
May 23, 2007 | 11:20 AM
  #40
Weekend Warrior
E Troop
163 Armored Cav
Montana Army Guard 1987-97
Reply 0
