Distributor lower gear clearance?
Old May 20, 2007 | 10:33 PM
19LEW71's Avatar
19LEW71
Default Distributor lower gear clearance?
I am in the process of rebuiling my tach drive distributor for 1971 base 350 and can't find what the clearance or play should be for the space between the actual distributor housing to the lower gear. I have some of the ground washers on order to take up some of the slack of the shaft up and down position currently .150 thousands.
I think thats excessive
Can any one give me the correct clearance.
Lou
Old May 20, 2007 | 11:08 PM
MCMLXIX's Avatar
MCMLXIX
.002 to .007
Old May 20, 2007 | 11:15 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
According to MSD and other references I have, 0.010" - 0.015" end play would be optimal. You typically do not want to go much tighter than 0.005". The 0.150" you have is reason for concern, and further diagnosis would be prudent as sloppy distributor clearances can cause spark scatter.
Old May 20, 2007 | 11:23 PM
19LEW71's Avatar
19LEW71
These (distributors) don't have the washer with the fold up tab??? is this correct.
Just the flat ground one's?
Old May 21, 2007 | 10:21 AM
lars's Avatar
lars
The cast iron distributors can be run pretty tight on clearance. I run about .005" to .007" as optimum. Aluminum-bodied distributors (MSD and HEIs) need a little more clearance, and I run those at .010 -.015". The iron distributors do not have the upper shim with the tabs - they use all flat shims. Moroso part number 26140 works fine.
Old May 21, 2007 | 11:33 AM
merlin5353's Avatar
merlin5353
St. Jude Donor '07-'08-'09-'10
What are the symptoms??
Old May 21, 2007 | 02:29 PM
TheSkunkWorks
While spark scatter can cause problems such as irratic idle, surging, sputtering, misfires (especially under load), increased fuel consumption and loss of performance, it may be detected early by periodic checks with a timing light before symptoms become very noticeable. Good cause to keep tabs on what's going on under the hood every once in a while, even when everything seems perfect.
Old May 22, 2007 | 11:24 PM
19LEW71's Avatar
19LEW71
Thank to all
I now feel better with the info
To Distributor lower gear clearance?
