81 radiator replacement
Old May 21, 2007 | 12:45 AM
vettekid93's Avatar
vettekid93
Default 81 radiator replacement
What is involved in replaceing the radiator in an 81 corvette?
How hard of a job is this?
Old May 21, 2007 | 09:37 AM
kevinator80's Avatar
kevinator80
Remove engine driven fan, unbolt shroud with aux. fan and slide back, remove brackets from each side of the radiator, remove hoses, disconnect trans. lines if automatic and lift. No biggie.
Old May 21, 2007 | 10:36 AM
SIXFOOTER's Avatar
SIXFOOTER
remove all the air intake plastic first, its on top of the radiator.
Old May 21, 2007 | 01:36 PM
Kalway's Avatar
Kalway
Probably take a couple of hours or so maybe. The basics have already been laid out above. Not too bad of a job, if you have the time. I miss the days of being single and having a whole weekend to do stuff to the vette...
Old May 21, 2007 | 08:15 PM
bertmeister's Avatar
bertmeister
Good time to also replace all the hoses and belts.
To 81 radiator replacement
