Timing mark jumping around
Old May 21, 2007 | 07:14 AM
Kev82vette's Avatar
Kev82vette
Default Timing mark jumping around
I went to set my timing and i noticed the timing mark jumping around. It was moving a couple of degrees hard to pinpoint actual timing. What would cause his??
Old May 21, 2007 | 07:27 AM
1stC3Vette's Avatar
1stC3Vette
Before looking for a mechanical problem, make sure you have the clamp placed properly around the #1 plug and that it is not touching anything. Fire the gun at some spot other than the timing mark and make sure it is constant with the engine rpm.
Good luck,
Dino
Old May 21, 2007 | 08:11 AM
corvetteload's Avatar
corvetteload
worn distributor bushings
Old May 21, 2007 | 09:58 AM
palamesa's Avatar
palamesa
A sloppy timing chain is a possible cause. How many miles on your engine?
Old May 21, 2007 | 10:09 AM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
If you put the calmp on upside down, the light is sporadic. Make sure the arrow is pointing towards the plug.
Old May 21, 2007 | 12:54 PM
Kev82vette's Avatar
Kev82vette
The engine only has 350 miles on it. I am not sure how old the distributor is.
Old May 21, 2007 | 01:24 PM
77BuffaloVet's Avatar
77BuffaloVet
I would start with the timing light as mentioned above, if it is reading another wire it will jump around. After that, I would check spark plug gap, wires and then the distributor...
Good Luck!!!
Chris
Old May 21, 2007 | 02:02 PM
427-390's Avatar
427-390
What he said. You are experiencing "timing scatter" The higher the RPM's, the more your distributer if vibrating up and down. I bet you could grab the top of your distributor cap and feel movement up and down. Ask me how I know. Replace the bushings. Good luck!
Old May 21, 2007 | 02:34 PM
Kev82vette's Avatar
Kev82vette
It seems to smooth out at 28oo or 3000 rpm. Its worse at idle.
Old May 21, 2007 | 03:39 PM
427-390's Avatar
427-390
What is your timing set for? Should be 36* total between 2500 - 3000 RPM with the vacuum disconnected.
Old May 21, 2007 | 03:54 PM
lars's Avatar
lars
There are a few things that will cause "timing scatter:"
  1. Excessive distributor shaft endplay. If there is excessive play in the shaft, the shaft will bounce up and down, advancing and retarding the timing. Shim the shaft to about .007" endplay using Moroso shims part number 26140.
  2. Slop in the breaker plate attach point. The distributor breaker plate is located in position with a hole for the vacuum advance control unit rod. This hole gets sloppy, and the plate bounces around. Remove the plate, lay it on a flat surface, and whack the hole with a hammer to tighten the fit yup and remove all slop.
  3. Bad distributor bushings. If the bushings have slop and the shaft has lateral movement, timing will be eratic.
So yank the distributor out and tighten it all up. This will produce rock solid timing.
Old May 21, 2007 | 04:11 PM
68coupe's Avatar
68coupe
I would start with the timing light because it is the easiest and cheapest place to start.
If the problem continues….
What type of advance springs do you have installed?
By that I mean what is the stiffness, if the they are not very stiff and the idle is high, then you may be experiencing some advance during idle. (Some early high performance models were actually setup this way.)
What is your idle set to?
What type od distributor?
What type of springs?
Also, it could be the vacuum advance. It may not be fully engaged at idle, you may not have enough vacuum to keep it open. (if it is connected to manifold vacuum.) The easiest way to solve this potential issue is to pull the vacuum hose off and plug it at the carb. See if the issue stops.
What type of vacuum do you have your vacuum advance connected to?
What is vacuum reading at idle?
What is the vacuum unit rated at? (or give me the model number)
Thanks,
Joe
Old May 21, 2007 | 04:40 PM
jim2527's Avatar
jim2527
I had the same problem. After pulling the distributor I found the endplay to be .045 were as the factory spec is .007. My rotor was moving up and down .038 extra!!! Spark plug gap is only .035!!!
Old May 21, 2007 | 05:16 PM
Rotonda's Avatar
Rotonda
Also look at the balancer. If it has some use, the rubber between the hub and outer ring can deteriorate and cause the mark on the outer ring to walk around.
Old May 21, 2007 | 06:40 PM
Kev82vette's Avatar
Kev82vette
I just disassembled my distributor and the plastic bushings under the advance weights are deteriorated and the weights were hanging up.
Old May 22, 2007 | 10:26 AM
427-390's Avatar
427-390
....and there you have it. Good job!
Old May 22, 2007 | 11:42 AM
bytor's Avatar
bytor
Where can you get replacement plastic bushings for under the advance weights?
To Timing mark jumping around
Old May 22, 2007 | 12:24 PM
lars's Avatar
lars
Hate to tell you, but that won't cause the problem you described. Jumping timing, or "timing scatter," is caused by the issues I outlined above. Sticking or binding weights will result in a slow timing curve or a short curve that does not return to the base setting consistently.
Lars
Old May 22, 2007 | 12:53 PM
Kev82vette's Avatar
Kev82vette
Well Iv'e never pulled a distributor so any advice so I don't screw that up? To answer the above question. I am running vac advance to manifold vac. and the vac can is ar28.
Old May 22, 2007 | 01:30 PM
BarryK's Avatar
BarryK
Kev
listen to Lars advice on your dizzy. As he says, excessive shaft play, play in the breaker plate, and/or bad bushings all will cause the problem you are having. At the same time, the erratic timing will cause you to never have the timing set correctly and this will also affect the timing and vacuum in your other post.
If you don't know how to rebuild your distributor, there is probably someone local that can do it for you. You might also check with Lars but while he rebuilds points distributors I'm not sure if he also offers his services on HEI units or not, I can't remember.
