Another power steering problem....
So far, I've replaced the pump, steering box, control valve, and ram, and the car is STILL hard to steer. I removed the control valve and took it to a local Vette place. There it was bench tested, and showed to be holding 1050 PSI in both directions when the ball stud was moved over. The valve was then re-centered on the bench. I installed the control valve and bled the system....same problem
So I started thinking, maybe I should re-center the valve on the car with the ram disconnected. I noticed it didn't take much turning in either direction to get the ram moving, but I did get the valve centered. Now for the interesting part....
With the car still running and on stands, I could turn the wheels by hand to get the ram moving, and noticed that with the ram moving out, I can still push it in with one hand. I can also pull the ram out when it's supposed to moving in. This doesn't seem right to me.... or is this normal? Would an internal leak in the ram cause this?
Would like to hear any suggestions
I think that if the car was on the ground with the ram disconnected from the frame, you would not be able to move the ram by hand if a helper tried to turn the steering wheel. The ram would move quickly to its stop and you won't be able to budge it by hand.
Jim Shea might chime in on this thread, he's very knowledgeable on C3 steering systems.
Joe
The amount of effort to steer the car is controlled by the springs inside the control valve.
Another factor that could cause heavy effort would be still having trapped air in the system. When you replace all of the major components in the system (control valve, ram, pump, hoses, etc) there are many places that can trap air and it might take considerable time to get it out. So even if you don't do a very good job of getting the air out before starting the engine, the air will work its way out of the system over several days as long as you drive and steer the system full lock to full lock a few times during that time.
Jim
Jim, I see you're from Saginaw. My dad lives in Clio, and my family has a long history working for GM in the Flint area. I try to go back there every few years when I get the chance
I was the supervisor of the flexible coupling, power steering hose, and hydraulic seal group from 1969 through 1985. (Beginning at the early part of the C3 era through the early years of the C4 program.) So I do have quite a bit of first hand engineering knowledge of the Saginaw parts.
I purchased brand new 1976 and 1980 Corvettes and began saving engineering information on the C3 models because of that fact. The information has become invaluable over the years!
Jim
I've noticed it doesn't take much adjustment of the control valve to get the ram moving. I only have to make about a 1/8 turn of the nut on the end either way to move the ram. Does that sound right, or is there a damaged seal(or something else) inside the valve?
Joe
The adjusting nut is real sensitive, and it is centered, so if that's right, I'll leave it alone
Thanks Joe
