Stoopid Fuel Injection (SFI) Question.
THE ENTIRE LEFT OR RIGHT BANK OF INJECTORS AT THE SAME TIME :eek:
Stupid Question(s): Is that how most fuel injection works? Firing a bank at a time? Did all pre-'94 EFI systems do this? What about the Ram-Jet 350? What about Holley & others aftermarket EFI systems?
Say it ain't so!
Daniel
Lower priced afternarket EFI system such as the Holley (that I'm running) are batch fire. More expensive systems such as Speed Pro, Motec, etc can be had as either batch or sequential. I think Edelbrocks Pr-Flo is sequential which is unusual in a "budget priced" system.
All this said though, it really isn't a big deal. When the LT1 went to SFI there was NO power increase. Not a single horsie. GM did it for emissions.
I think only Mitsubishi has done this.
I doubt youd see direct injection anytime soon in a vette.
I wouldnt get an EFI system that isnt sequential.
If anything id get victor junior manifold and have injector put in and have a computer like motec etc and have it do sequential EFI and controll the ignition.
Chris :cheers:
I a little confused... SFI does not make any more power than batch fire. There is no driveability change. Mileage is theoretically up maybe 1%, but not enough that it can be measured. Only benefit is emissions (and not much there either). Drawbacks of SFI is that you need either a crank sensor or a modified distributor so that the ECM knows what cylinder is firing. You also have a lot more wiring to worry about as every injector has to have individual wires to the ECM.
Not worth it to me...
As for direct injection, it's coming out now from GM. They are prototyping it for release in a few years. All indications point to the next GM V8 having the injectors spraying straight into the chamber. Again, no real power benefit, but it cuts down a little on the emissions.
for the intake stroke.
for sequential it puts the fuel in when its taking air in so its more efficient.
as for direct injection it lets you inject when the valves are closed.
little differences but they do make an effect however small.
