Calling All Australians
Old Oct 23, 2001 | 10:01 PM
Brutus's Avatar
Brutus
Default Re: Calling All Australians (67HEAVEN)
The first BBQ I ever attended in the States had me running for cover!
The guy who was starting it brought out this bloody big squirt bottle of lighter fluid! I thought I was going to end up like this :blueangel:
We don't have anything like that over here. Lighter fluid to us is what goes into cigarette lighters and is extremely flammable!
You need to try an Aussie BBQ with gum leaves thrown on for a fragrance and flavour you'll never forget.
Old Oct 24, 2001 | 12:36 AM
jdunne's Avatar
jdunne
Default Re: Calling All Australians (Brutus)
Bob,the ford steering box was used as it is the same ratio as the chev box....no power steering on mine,far too jiggly....at speed it is more stable without the p/s....parking is character building......as for the barbie,we in melboure thought it was some sydney thing to cook prawns like that.....never seen it done here....the only times i have had barbequed prawns is in chinese/asian restaurants....john :chevy
Old Oct 24, 2001 | 01:27 AM
Brutus's Avatar
Brutus
Default Re: Calling All Australians (jdunne)
This Toyota box I have is pretty vague as is so I'll see about changing over when the motor is out.
My last car (XB GT Coupe) had non p/s originally. It had 265s on the front and 315s on the rear and was definitely fun when parking. Finally changed it over to a Landau p/s system.
That shrimp crap was some ad man's idea to attract tourism over here by making out that we called them shrimps in Oz. I've never thrown a bloody prawn on a BBQ in my life. :)
Old Oct 24, 2001 | 03:13 AM
Chris O''s Avatar
Chris O'
Bob
If you have the Cressida box (like I have), it is a far superior box than the ford unit (but also bigger). If you drive it a lot, the toyota box may be worth keeping.
Old Oct 24, 2001 | 05:56 AM
Brutus's Avatar
Brutus
Default Re: Calling All Australians (Chris O')
Thanks Chris....yes the one I have is the Cressida box from what I'm led to believe.
I wasn't aware of the superiorty of either box. I was of the impression that the Ford one was fairly good tho.
I'll check out some local repairers and see what can be done to improve or at least recondition the one I have.
[Modified by Brutus, 7:59 PM 10/24/2001]
Old Oct 24, 2001 | 08:48 PM
Chris O''s Avatar
Chris O'
The good thing about the ford box is waaaayyyy cheaper to reco than the cressida. Some guys have paid up to $800 to reco the cressida:eek: , but one from the wreckers is around $150-$200. Have you got headers on your car? It looks as if I'll have to lower the p/st lines that go into the top of the cressida box to get any sort of clearance on mine.
:cheers:
Old Oct 24, 2001 | 11:14 PM
jdunne's Avatar
jdunne
Chris,i think the ford box was A$180 new.......john :chevy
Old Oct 25, 2001 | 01:36 AM
Chris O''s Avatar
Chris O'
Yeah, big difference in costs. :eek:
Old Oct 25, 2001 | 02:25 AM
Brutus's Avatar
Brutus
Chris...I'm not sure whether my box needs to be reconditioned or not, but I just have a tendancy to renew anything and everything as I get to it.
Sort of like some sort of obsessive compulsive disorder. :rolleyes:
Btw, what do you think of your XE 256 cam? I have an XE 262 ready to go into mine along with the AFR 180 aluminium heads. I'll be wanting some nice extractors too while I'm at it.
Old Oct 25, 2001 | 07:05 AM
jdunne's Avatar
jdunne
Bob,while you are looking at the steering for poss probs,have a look at the rag joint.....you would be surprised how often it is the prob assuming the box is adjusted to spec......john :chevy
Old Oct 25, 2001 | 09:09 AM
Brutus's Avatar
Brutus
John...I have a nice new poly rag joint already to go in. it's made to fit a HQ but will easily go into mine.....so I'm told....acording to Pedders suspensions
Old Oct 25, 2001 | 10:52 AM
xrated's Avatar
xrated
Brutus what did the AFR 180 heads cost you? Did u buy them complete with rockers and valves? What are the valve sizes?
Old Oct 28, 2001 | 10:32 PM
  #33
Chris O''s Avatar
Chris O'
Bob
I would have to say I am a little disappointed with my XE256 cam, so far. I think I am running too lean and am in the process of rejetting etc. I have the stock exhaust and no doubt that headers with straight through mufflers would make 40HP difference. It has a nice note to it though and can really boogie into second compared to the stock cam. I still can't smoke em (or spin 'em that much) yet but I hope my carb twiddling will cure that.
P.S. with AFR heads and headers, yours should really scream! I too am obsessive compulsive but my income does not compliment my disability. :D
:cheers:
[Modified by Chris O', 9:00 AM 10/30/2001]
Old Oct 29, 2001 | 06:59 AM
  #34
Brutus's Avatar
Brutus
xrated...You really don't want to know what those heads cost me in total. Howard wants to shaft you with his bloody GST at every opportunity.
The AFR heads come with all the right gear...guide plates and CNC machining...plus they just look great to boot.
Chris...That's a shame about your 256 cam. I hope the 262 plus all the other goodies I've accumulated will all go togther to give me the package I'm looking for.
