LS Engines? +'s & -'s?
Let me know how it works out when you go in. It may save me a ton of work. I'm planning on making my own fuel tank using the LS1 Camaro fuel pump/sensor set up. My tank will be oversized and lowered into the old spare tire area. I'll be using C6 run flats from here on out. Let me know if you need help making a tank for your....I'll make 2......gp
I used the CARB... instead of the wiring harness and fuel system...
I also kept my TH350 and have a 3000 non locking stall converter
ls6 heads... and comp cam 581/581 lift dual plan intake
the shop I used did a good job... but DID NOT finish the JOB the right way the first time... and left me electrical issues... so I am overall not satisfied with the over all job they did...
getting the motor in placing it right and the FAB work was great. BUT fit and finish sucked. I knew a few guys in the shop (the techs) and they said the owner slammed the job in the last few days to get PAID... pissed me off.
but over time and with the help of some friends I am getting there
My LS1 is stock except catback and air filter, can't complain about performance and reliability, 100K miles without any problems
Aftermarket performance parts are very expensive for these engines, a lot more expensive than for the older LT1 engines.
If you're looking for a reliable and fuel efficient engine/trans combo I'd suggest a LT1/5spd combo out of a 94-97 Fbody, these are almost dirt cheap.
Take a look at the great deal you can get on a set of modified L92 heads and an LS7 intake with fuel rail, http://www.slponline.com/view_product.asp?P=12293. Not only is this set up availible at a bottom dollar price, it also happens to make power comparable to high dollar AFR set ups (see the latest issue of GM High Tech). These heads are simply modified GM units that flow numbers only dreamt about a few years ago. When LSX engines were first being modified the market was small and parts were expensive. Spending several thousand dollars for minimal gains was common place and tuning was next to impossible just a few years ago. The market has since grown to be much larger than the LT1 market ever was or wished it could be, resulting in an abundance of aftermarket parts and competition. The competition has bred cheaper parts that out perform any thing ever available for an LT1. Today you can build a 500 rear wheel horse power daily driver LS1 car that idles with only an ever so slight thump. LS1 technology is now at the point where Joe Smo and his junk yard LS1 with a stock bottom end and stock heads can put 420hp down to the ground with a cam and simple bolt-ons. While it might have been true 5 years ago that LSX engines were more expensive to build than LT1 engines, today they are considerably cheaper and more efficient.
However, if I was looking for an engine to put in my old pick up….yeah I might pick up an LT1, but not for my Corvette. LT1 motors have an inexpensive initial investment and make for great replacement engines. Recently I picked up an LT1 with wiring harness and no ECU with 79,000 miles on it for $750; what a deal! Now, to do a swap into a non-LT1 car I still would have needed an ECU, Trans, Driveshaft and trans crossmember, so don’t get too excited about the $750.00 price just yet. LT1’s are great, but you will always wish you had an LS1.
I am in the personal opinion that LS1 motors even with a higher initial cost are better in the long run. It’s not that LT1’s are bad, there are just better options out there these days for performance cars.
Complete "take out" LT1 can be found for less than $2000 and that often includes the trans and computer, fuel injection and so on...a compareable LS1 is about $4000 (that's an estimate based on the market here in Orlando, I had an offer for a complete LS1/6spd combo not too long ago)
One ignition coil is $50 (MSD $80) and you need 8... cyl heads are around $2200 and up.... Cam and coil springs are about $600 ... that's why I'm thinking the LS1 parts are a little expensive....
If you only want to upgrade the old carburated engine with a FI engine the LT1 is a good choice...
I agree, you'll still want the LS1.... when you have an LS1 you want an LS6 and so on....
Back to your statement about wanting LS1, then LS6....what do you think is going to happen to the poor saps dropping LT1's in now when in a couple years everyone else is walking away from them with LSx's?
Pat, I need to raise my pesty rev limiter too. Matt hooked me up with a LS1 tuner guy and I forgot to have him move mine to 6500.
I agree an LS1 can be expensive to purchase. As for coils.... they rarely go bad and when they do you can upgrade to heavy duty factory take off truck coils cheaply. As for heads, they are becoming dirt cheap; take a look at the link I provided above. You even get the LS7 intake and complete fuel rail with injectors for $2,295! http://www.slponline.com/view_product.asp?P=12293 http://www.slponline.com/view_product.asp?P=12293 Cams are really no more expensive than swapping to a roller set up in an SBC. I owned LT1 cars in the past because the part were cheap and I could make power without draining my wallet; I switched when that was no longer true.
Correct the original poster did want a mild street car with good mileage and either engine would be a good choice. I am just Pro-LS1.
A good friend of mine has an old RX7 with an LS6 putting 500HP down at the wheels.... and the car is only a little over 2000lb.
2 years ago I bought an 95 BMW 318 to swap an LS1 into, but sold it to purhcase a Z28. These swaps are common place, just take a look at the conversion section on the LS1TECH message board.
Ha, I didn't realize Budman78 had an LS car. I guess I got a little excited talking about LS1s and my mind went crazy.... Sorry Budman
SuprJames, you got a sweet deal on those LS6 heads.
Hopefully you're right and I never need new coils....
I have been pricing some upgrades on my LS1: cam, lifters, pushrods, springs and retainers.... incl oil pump, timing chain set and gaskets and head bolts I was at almost $1500
Then I decided that a stock LS1 isn't that bad....
