SBC cam questions
Old May 24, 2007 | 09:16 AM
Bangkok Dean's Avatar
Bangkok Dean
Default SBC cam questions
I am looking to change out my mild Edelbrock Performer hydraulic cam.
I want a little more power and a lumpy idle with out loosing vacuum.
I have the Edelbrock Performer RPM heads and intake with a little over 9 to 1 compression. I am looking at the Edelbrock 5002 that should work ok with my heads and still use hydraulic lifters.
Is there a better cam available?
Old May 24, 2007 | 09:34 AM
Ganey's Avatar
Ganey
If you had the RPM cam, you would have a lumpy idle. You may have Performer 2102.
For cam, trans.(stall if auto.) & rear gears are needed. Is gas mileage an issue?
Old May 24, 2007 | 10:21 AM
Bangkok Dean
Ganey,You are correct 2102 is what I have now. It is a 4 speed manual trans 3.08 rear gears. Mileage is not an issue (yet)
What do you think?
Old May 24, 2007 | 10:28 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Summit 1103 would be a nice upgrade and still be driveable with good low end power and vacuum. You'll need 1.6 ratio rocker arms, the lift is a little low with stock rocker arms.
Brand: Summit
Product Line: Summit Camshafts
Part Type: Camshafts
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,000-4,500
Intake Duration at 050 inch Lift: 214
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 214 int./224 exh.
Advertised Intake Duration: 272
Advertised Exhaust Duration: 282
Advertised Duration: 272 int./282 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.442 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.465 in.
Valve Lift with Factory Rocker Arm Ratio: 0.442 int./0.465 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Quantity: Sold individually.
Old May 24, 2007 | 10:43 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Look for something around 228-230* @.050 W/110 LSA
Old May 24, 2007 | 10:50 AM
Bangkok Dean
Brand: Summit
This is the info on the EDL-5002
Basic Operating RPM Range: 1,500-6,500
Intake Duration at 050 inch Lift: 232
Exhaust Duration at 050 inch Lift: 234
Duration at 050 inch Lift: 232 int./234 exh.
Advertised Intake Duration: 292
Advertised Exhaust Duration: 300
Advertised Duration: 292 int./300 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.488 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.488 in.
Valve Lift with Factory Rocker Arm Ratio: 0.488 int./0.488 exh. lift
Lobe Separation (degrees): 108
Old May 24, 2007 | 11:22 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I've had the Performer RPM cam and I did not like it all all, the numbers are similar to what you posted (234-240, .500" lift). It's too much cam for a low CR small block, vacuum was bad as well.... I then downgraded to the performer cam which was big step down... more like a truck camshaft.... the 1103 cam is pretty much between the two and is reasonably priced, Comp, Crane or lunati have similar grinds.
Old May 24, 2007 | 11:36 AM
Bangkok Dean
Does the1103 have a lope idle also?
Old May 24, 2007 | 11:55 AM
Tom1701's Avatar
Tom1701
Just ran across this the other day. It might be a look at if you want lope.
http://www.compcams.com/thumpr/
LL&P
Tom1701
Old May 24, 2007 | 11:58 AM
jackson's Avatar
jackson
I want fancy stainless sidepipe covers without spending several hundred $.
Old May 24, 2007 | 12:03 PM
Bangkok Dean
Old May 24, 2007 | 12:11 PM
dgruenke's Avatar
dgruenke
Oh come on, give him a break. We have to pay for that new cam.
Old May 24, 2007 | 12:14 PM
Bangkok Dean
LL&P
Tom1701
Neat but a little pricey and I don't know if it is compatible with my valve springs?
Now if someone were to buy some Steelshields then maybe.
Old May 24, 2007 | 12:20 PM
Little Mouse's Avatar
Little Mouse
Way to much duration with only a little over 9.1 comp.
Mid range upper rpm cam with 3.08 rear gearing= bad combo.
Old May 24, 2007 | 12:31 PM
Bangkok Dean
Originally Posted by Little Mouse
Way to much duration for a 350 with only a little over 9.1 comp.
OK, Thanks but what other cam would you suggest to give a lope idle and a little more power, Plus not break the bank?
Old May 24, 2007 | 12:33 PM
Tim H's Avatar
Tim H
You can't beat the Summit cams right now, they are on sale for $52 bucks!!!!!!!! Most are 112 or 114 lobe separation ,which means they are not real lopy but have good power ranges.
Old May 24, 2007 | 12:43 PM
Bangkok Dean
This is what I have now, runs good but idles too smooth.It is a 350.
Product Line: Edelbrock Performer-Plus Cam and Lifter Kits
Part Type: Camshaft and Lifter Kits
Basic Operating RPM Range: Idle-5,500
Intake Duration at 050 inch Lift: 204
Exhaust Duration at 050 inch Lift: 214
Duration at 050 inch Lift: 204 int./214 exh.
Advertised Intake Duration: 278
Advertised Exhaust Duration: 288
Advertised Duration: 278 int./288 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.420 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.442 in.
Valve Lift with Factory Rocker Arm Ratio: 0.420 int./0.442 exh. lift
To SBC cam questions
Old May 24, 2007 | 01:44 PM
Little Mouse
SUM-1103 would be a good torque cam for your 3.08 rear, but
it probably won't give you enough rumpity idle you want. the
SUM-1104 with 224 at .050 duration will give you the rumpity
but not as good a match for your gearing as the SUM-1103.
If your willing to spend more money this high lift cam
has duration figures in between the two summit cams and has
better lift.
Part # LUN-60102, $122.39
int. dur. .050, 219
ex. dur. .050, 227
int. lift, 468
ex. lift, 489
LSA 112
Old May 24, 2007 | 02:01 PM
Bangkok Dean
better lift.
int. dur. .050, 219
ex. dur. .050, 227
int. lift, 468
ex. lift, 489
LSA 112
The LUN-60102, $122.39, is cheaper than the Edelbrock cam set. But will it give a rumpity idle?
the SUM-1104 is not much diffrent tham what i have now.
Old May 24, 2007 | 02:18 PM
jackson's Avatar
jackson
Perhaps someone didn't get the point ... everythings a tradeoff ... lumpy v. vac & shiney v. cheap.
Sealed power has cam similar to lun60102.
SP # CS1062R ....... 220/231, .468/.480 ICL 110
Check w/ fine69 on "other" forum ... he's running it & quite pleased.
