What's the difference
Old May 24, 2007 | 11:44 AM
Rab16's Avatar
Rab16
Default What's the difference
What's the difference between the '70-'76 upper dash pad and the '77 upper dash pad. I'm asking because I found a '72 dash on Ebay and I want to make sure it will fit my application.
Old May 24, 2007 | 12:39 PM
...Roger...'s Avatar
...Roger...
Should be the same.http://www.ecklers.com/product.asp?p...4&dept_id=1656
Old May 24, 2007 | 12:41 PM
markdtn's Avatar
markdtn
77 upper dash pad is all by itself. I do not believe the earlier ones will interchange with it.
Old May 24, 2007 | 12:47 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
77s got the new center cluster and console (plastic). Center cluster is one year only and that might make a difference in the dash pad.
Old May 24, 2007 | 12:50 PM
...Roger...
I think they will fit just fine its just that 77 has a smooth front edge and the others have stiching on the front edge.
Old May 24, 2007 | 04:15 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Correct answer. The 77-only pad wasn't available in repop when I replaced mine years ago...the earlier pad fits fine.
Old May 24, 2007 | 06:41 PM
Rab16's Avatar
Rab16
Alright thanks guys that will widen my search and make finding a pad much easier.
To What's the difference
