questions on 69 vert carpet install
Old May 24, 2007 | 10:22 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Default questions on 69 vert carpet install
any body have any pictures of there 69 vert interior carpeting that they can share....especially of any fasteners used.
here is how i think its suppose to go...how high up is the back suppose to go up?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old May 24, 2007 | 10:51 PM
sperkins's Avatar
sperkins
Bob, I had that exact same situation with my '68. I couldn't get it to fit exactly right so I did it the best way I could. As far as I know, there are no fasteners to help hold the carpet up. I glued mine just under the lip that is just under the vents back there and trimmed the excess at the front at the storage compartments. Once you have the deck lid closed and the top down, there is no way you or anyone else will notice it. Here is the only shot I have on file at the moment.
Old May 25, 2007 | 09:17 AM
bobs77vet's Avatar
bobs77vet
thanks scott any other pictues you have i would appreciate seeing.....carpet installs is not my strong suit. thks bob
Old May 25, 2007 | 12:34 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by bobs77vet
...[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
You're headed in the right direction. Looks pretty good.
Old May 25, 2007 | 01:08 PM
Wrencher's Avatar
Wrencher
No fasteners, it glues in. Yours fits WAY better than mine ever did! The carpet kit was in a pile of parts I got with the car, and not a very good one at that. I had it professionally installed and it came out nice.
Hans
Old May 25, 2007 | 05:26 PM
bobs77vet's Avatar
bobs77vet
ok guys thks ...........tonights the night
i took off today and this morning the Mrs and I took a cruise from our house all the way down south along the shore it was a great cruise about 2 hrs long and coming back the line of cars invading the shore towns had already started!!!!!!!!!!!!
Old May 25, 2007 | 11:51 PM
bobs77vet's Avatar
bobs77vet
ok first lesson make sure you have a solvent to get glue off of your new carpet.........
[IMG][/IMG]
the glue gets sprayed liberally
[IMG][/IMG]
[IMG][/IMG]
i used some foam to build out the back as a flat surface
[IMG][/IMG]
[IMG][/IMG]
i used glue and then clamped the carpet down
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
i will finish it up tomorrow, i even used a straight razor and didn't slice up my fingers...now thats a first
Old May 26, 2007 | 09:56 AM
sperkins's Avatar
sperkins
Ah... You knew you could do it!
I'll bet 100 buck that your carpet came from Wilcox (or ACC).
Old May 27, 2007 | 10:28 AM
bobs77vet's Avatar
bobs77vet
it came from wilcox
[IMG][/IMG]
[IMG][/IMG]
Old May 27, 2007 | 10:39 AM
dragonracer's Avatar
dragonracer
Is wilcox the best? I need a kit but really want one that won't wrinkle or be too hard to install since I have to do it myself.
Old May 27, 2007 | 12:26 PM
sperkins's Avatar
sperkins
I knew it. Wilcox sells ACC carpet. ACC needs to fix their crappy mold. Mine had the same baggy area around the wheel well. I complained about my fit here on the forum and stirred up a damn hornets nest.
http://forums.corvetteforum.com/show...=wilcox+carpet
I guess ACC uses their own mold, but it isn't right!!!
it came from wilcox
[IMG][/IMG]
Old May 27, 2007 | 10:06 PM
bobs77vet's Avatar
bobs77vet
i'm not sure why it is baggy but i can't argue with your comments it seems like it could have been a little tighter
Old May 28, 2007 | 11:41 AM
gator79's Avatar
gator79
mine is ACC and it looks exactly like that, thought about putting some foam behind it to make it look better. only good thing is the top will be down 99% of the time and it wont show
Old May 31, 2007 | 01:04 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
We recently sent them photos of the exact same issue on a car in our shop.
As with your problem Scott I hope the second set we sent to you worked out, and I offer the same offer I did to you too this customer.
Call customer service at 800-588-3883 and tell Norm, Joe, Tom what your problem is. Please if you can email picture to us at Tommy@willcoxcorvette.com we would be happy to forward it to ACC.
We have very few problems with ACC carpet sets, but this one issue seems to be something that keeps popping up! We alone can not fix this issue. While every aspect of ACC carpet is in the original GM design down to the number of threads per inch from 1953-1993, it appears as if this mold has been moved to the wrong size.
I ask each and everyone that has a Convertible from 1968-1975 to go to the ACC web site at http://www.accmats.com and email them this info. Put it attention Randy Cotton or Roger.
Maybe the mass’s can get their attention. If you have original carpet in your car, this would even help us more. You can tell an original carpet set from the reproductions by the JP Stevens logo tag attached to the back of the carpet sections.
In the mean time, if you want us to replace this T-Section, I would be happy to. I’m lost as to why you received one this size since we just called them with the exact dimensions on this carpet section two months ago.
Regards,
Willcox Inc.
Old May 31, 2007 | 01:09 AM
0Willcox Corvette
Former Vendor
I forgot, there should be three plugs that push through the back wall of the carpet in to the rear body section. These are called carpet fasteners. They are rubber and hold the carpet to the back wall.
Old May 31, 2007 | 12:31 PM
bobs77vet's Avatar
bobs77vet
ok thanks for the answer but i got there first
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
To questions on 69 vert carpet install
