Engine wont fire
Old May 25, 2007 | 12:51 PM
Mikes*Corvettes's Avatar
Mikes*Corvettes
Default Engine wont fire
This is driving me crazy.
Just fitted a new engine to a 79 project I'm working on.
But the sob wont start.
It just keeps popping through the carb.
I have set timing as per Lars's papers,
bought no1 cylinder to tdc on compression stroke lined up the dizzy but it still pops through the carb.
The engine is a newly rebuilt unit which i bought and did not rebuild.
Do you think that i may need to degree the cam first before doing timing.
Any ideas.
Old May 25, 2007 | 12:54 PM
piper.gras's Avatar
piper.gras
if you had #1 at tdc and set the rotor pointing to the #1 plug wire, your timing is too retarded. try advancing your timing 12-16 degrees.
Old May 25, 2007 | 01:22 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Dell Boy
...It just keeps popping through the carb.
Timing. You've got a valve open/opening when it should be closed. And, yes, following a cam swap, you should degree the new cam. May not be off much, but could be off just enough to be causing your problem. In your case, if you did not rebuild the engine, you might want to take a look at the timing set. Chain is probably stretched, or she jumped a tooth or two.
Old May 25, 2007 | 01:55 PM
RPOL68's Avatar
RPOL68
Check your firing order again. You are getting spark when an intake valve is open. Either your timing is way off or you have some wires crossed.
1-8-4-3-6-5-7-2
....F....
1.......2
3.......4
5.......6
7.......8
....O....
Old May 25, 2007 | 02:41 PM
bradzap's Avatar
bradzap
Sounds to me like you put the distributor in 180 degrees off. I've done this myself before and had the same issue you are having.
Just a thought.
To Engine wont fire
