SBC accessory mount holes
Old May 26, 2007 | 11:29 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Default SBC accessory mount holes
How deep are the 3/8-16 holes in SBC heads? I need to drill and tap one that was never drilled on my passenger-side head.
Old May 26, 2007 | 01:45 PM
1982CorvetteDude's Avatar
1982CorvetteDude
You don't need to do that, it will hold up just fine w/o that extra mounting point
I did the same thing on my Blazer and never had any problems, just bolt it up and go.
Old May 26, 2007 | 02:37 PM
Durango_Boy's Avatar
Durango_Boy
I agree, that extra hole would be nice but not needed in my opinion. Just make sure, as I found out, that some of my bolts were bottoming out and were about 1/16" too long and I wasn't getting the bracket securely bolted to the block. Check depth and trim the bolts if needed.
Old May 26, 2007 | 08:25 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I just figured since the other side has five mounting points, that having four on the tensioner side would be a good thing. I have to take the bracket back off and trim a bit of it to clear the compressor lines, anyway...figured I could use the bracket as a drill guide, then tap the head once the bracket is off.
Old May 26, 2007 | 08:36 PM
Durango_Boy
Be careful when doing that. That aluminum is very soft and the bit spinning with any kind of lateral force will waller out that hole. I would use the bracket as the guide for a mark only, then pull off the bracket and drill the hole free hand.
I contemplated all this as well since the 350 heads in the car right now don't have that third hole.
To SBC accessory mount holes
