1982 windshield replacement question???
Old May 28, 2007 | 01:44 PM
funymuny's Avatar
funymuny
Default 1982 windshield replacement question???
Suffice to say I was STUPID; getting windshield replaced tomorrow. Can I salvage the moldings? The side moldings come off easy (learned that when I replaced the weatherstripping). I cannot readily tell about the molding that runs across the outside top.
How is the top molding secured? Re-useable?
Thanks, Mark
Old May 28, 2007 | 04:05 PM
mooneyd's Avatar
mooneyd
I had my '82 windshield replaced and they put all the moulding back in place just fine. Just hope there's not a lot of rust under there.
Old May 28, 2007 | 05:40 PM
funymuny's Avatar
funymuny
I've poked around a little. Dirty but really not much in the way of rust......lucky.
Is the moulding secured with screws? They slide the glass up under the moulding without removing it?
Old May 28, 2007 | 07:49 PM
SIXFOOTER's Avatar
SIXFOOTER
The moulding is secured with clips and the trim is reuseable. you can get the clips loose with a thin bladed screwdriver
Old May 29, 2007 | 05:17 PM
funymuny's Avatar
funymuny
They've been here and done it. Everything worked fine. Thanks for the comments!
Mark
To 1982 windshield replacement question???
