L88 hood set up for small block
Old May 29, 2007 | 05:55 PM
Dan Michael's Avatar
Dan Michael
Default L88 hood set up for small block
Has any one hook up a L88 that drafts air like the big block ; but hooked it up to a smalll block and what changes did you make !
Old May 29, 2007 | 11:07 PM
Crunch-o-Matic's Avatar
Crunch-o-Matic
what?????????
Old May 30, 2007 | 10:03 AM
jbroughton's Avatar
jbroughton
I think he's talking about using the air box on an L88 hood with a small block.
I've got the hood on mine, but not the air box setup, just an open air cleaner. I'm sure it could be done... may take a little fabrication. I've wondered the same thing myself.
Old May 30, 2007 | 10:34 AM
SIXFOOTER's Avatar
SIXFOOTER
All you have to do is add on the air box to the underside of the hood and cut holes in the backside if its not already open. Put on an L88 air cleaner and your in business
Old May 30, 2007 | 10:42 AM
SteveG75's Avatar
SteveG75
It can be done. Someone here did it with a small block before he swapped to a 454 but the name escapes me.
You may need a spacer to bring the carb/air cleaner up to where it will seal to the hood but that is about the extent of issues.
Old May 30, 2007 | 10:57 AM
Crunch-o-Matic
ok got it...
Old May 30, 2007 | 11:49 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Doesn't matter, small block/bigblock just round up the L-88 air cleaner parts add the airbox to your L-88 hood do a little measuring yada yada...cold air intake
To L88 hood set up for small block
