Temp Higher after adding
Old May 30, 2007 | 02:53 PM
PETKAH's Avatar
PETKAH
Default Temp Higher after adding
Overflow tank was empty so I filled it with premix anti freeze to the
proper level in my stock '75. Temp gauge was always running at about
the 180 hash mark. When I recently drove it with outside temp at
about 90 degrees temp gauge was just below 200. Any ideas why
this would happen?
Old May 30, 2007 | 03:51 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Sounds okay to me, especially in 90 degree weather. I would be more concerned finding no coolant in the overflow. How old is your radiator cap?
Old May 30, 2007 | 04:13 PM
PETKAH's Avatar
PETKAH
Cap is probably about 4 years old - never a problem with leakage or
steam.
Thanks for your response!!!
Old May 30, 2007 | 04:25 PM
Roughrider's Avatar
Roughrider
I agree...200 degrees in 90 degree temps seems normal. It may simply be a coincidence.
Just to make sure...pressure test your cooling system and the radiator cap. If it's not holding pressure, you need to find out and correct it immediately. This is preventative if nothing else. Heading into summer and high temps you don't want to find out you have a bad hose, blown head gasket or worse.
This isn't all that likely but what at you might find is there may be air in the coolant system if it was low and added coolant without burping it. Let it run up to normal temp with the radiator cap off and let any air in the system come out. Then you can check the level and see if it's correct and add more while the engine is running to let it circulate and let any additional air out.
To Temp Higher after adding
