Slightly off topic - Need Camaro advice
Old Oct 23, 2001 | 11:44 PM
rafox77's Avatar
rafox77
Default Slightly off topic - Need Camaro advice
my '86 Camaro :chevy started leaking antifreeze the other day. Looks like it's coming from the drain plug, tried to tighten it but it won't snug up. Do I need to remove the plug (and drain the radiator) to replace it :confused: . Any help would be great!
Old Oct 24, 2001 | 01:14 AM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Slightly off topic - Need Camaro advice (rafox77)
My only suggestion would be to open the drain (is it a plug or a petcock?) and then close it. That may re-seat it enough to seal. Otherwise, drain the system and replace it.
