New to the forum, great source of info, thanks. I just put new trailering arms on my 69 with an offset. Anyone know how wide of tires I can put on now. I don't want them to stick out of the wheel wells, just want fatter tires that look good.
Yesss i beat batman to it.
Try the search function...you'll find more information on wide rear tires with offset TA's than you will be able to shake a stick at.
I installed 275/60-15 on my 68 rear on 8 " stock rims and found that this is the largest possible as otherwise the tire will hit the fender when moving upwards.( tried it by disconnecting the sping and push the tire all the way up until the T/A pumper hits the frame ).
If you have offset T/A and want to use this space, you need to get different rims that take the tire more inwards ( or different backspacing ).
