Remove Muffler to change antenna?
Jun 3, 2007 | 01:30 PM
I am assuming you have to remove the left side muffler to change the radio antenna?
am I correct in this assumption?
Jun 3, 2007 | 01:55 PM
Thats the easiest way.It can be done with out removing but you will probably cuss alot.
Jun 3, 2007 | 02:16 PM
It can be done with the muffler in and dropped but it is easier to remove it and get some room to work.
Jun 3, 2007 | 02:20 PM
Quote:
Originally Posted by
DWncchs
Been there done that.
Jun 3, 2007 | 05:09 PM
I did with muff in place, and with no helper, at night. Many horrific words and phrases were uttered, mainly due to lack of a helper to start top piece. If you have Paul Sr. arms or hands, I would plan on removing the muffler.
Jun 3, 2007 | 06:49 PM
Thats how I did it. You might be able to do it by removing the spar tire carrier instead. Not sure about that.
Jun 3, 2007 | 06:56 PM
If you use the antenna to pull every thing up into position it can be done with the spare tire carrier down.
Jun 3, 2007 | 08:47 PM
Remove the rear Y pipe and mufflers as an assembly, just behind the converter.
Steve
Jun 4, 2007 | 12:55 AM
My mufflers are tack welded on. Had no choice but to use the antenna. If you're talking a whip antenna you can do it with the muffler in place. If your muffler comes apart, save some time and frustration and remove it.
