Shimming front end
Old Jun 4, 2007 | 08:40 PM
pik's Avatar
pik
Default Shimming front end
How many locations do you need to add shims to if trying to raise the front end to close the uneven gap at the doors?
Where can you buy these shims?
I tried searching threads, but am still a little in the dark.
Old Jun 5, 2007 | 01:16 AM
wombvette's Avatar
wombvette
You will have no luck trying to close the gaps on a `77 with shims or front end adjustments.
Old Jun 5, 2007 | 07:58 AM
pik's Avatar
pik
Mine is a 79.
Old Jun 5, 2007 | 08:30 AM
LYLE's Avatar
LYLE
The fenders are bonded soild to the cowl so shims won't help unless you are installing a new front end.
Old Jun 5, 2007 | 04:30 PM
crf311's Avatar
crf311
You need to make the adjustment with the door hinges. It's a major pain in the A--. Took me about 8 hours just to do one door.
Old Jun 5, 2007 | 04:39 PM
Artsvette73's Avatar
Artsvette73
Old Jun 5, 2007 | 04:50 PM
Belgian1979vette's Avatar
Belgian1979vette
Previous posters are right, no adjustment that way in the area of the doors.
Old Jun 5, 2007 | 10:03 PM
pik's Avatar
pik
It looks like at some point in the past the core support has been replaced. After removing the doors, I can see some separation at the top near the windshield. This initially lead me to believe I could shim the front up to close this gap.
Old Jun 5, 2007 | 10:15 PM
dannyman's Avatar
dannyman
Post pictures of both sides showing complete doors and fenders.
Old Jun 5, 2007 | 11:02 PM
pik's Avatar
pik
Here are a couple of pics.
The drivers door is not closed all the way.
http://i180.photobucket.com/albums/x148/p1k68/vette.jpg
http://i180.photobucket.com/albums/x...68/vetteii.jpg
Old Jun 5, 2007 | 11:10 PM
big_G's Avatar
big_G
Not.
The fenders bond via extensions which in turn are bonded/riveted to the cowl and firewall. This fact will allow some flexing. This can be seen in action if you jack up the 'Vette in the center of the frame, under the door. The door to fender cap will grow as you jack up, due to frame sag. Minor (1/4 inch or less) adjustments can be made to the upper door/fender gap by shimming up the radiator support or repositioning the frame extensions.
Old Jun 6, 2007 | 09:13 AM
wombvette's Avatar
wombvette
Heck,
Thats about as good as they were in `79. Some much worse.
Old Jun 6, 2007 | 09:24 AM
LYLE's Avatar
LYLE
Originally Posted by big_G
Not.
I knew the extensions were their but have never tried to make the gap less only when bonding on a new front end. If I have a chance to need to try this I sure will as I can see how it could make a small change in the gap and sometimes that is all that is needed.
Thanks for the tip
To Shimming front end
