Question about Spark Plugs
Old Jun 5, 2007 | 06:12 PM
427basketcase's Avatar
427basketcase
Default Question about Spark Plugs
Hello all, I am about to convert from dual point to HEI on a 69 427 / 390, with a mild cam, and headers. What plug and gap would be recomended?
Old Jun 5, 2007 | 07:01 PM
Roughrider's Avatar
Roughrider
To start, I'd stick with the stock application...maybe open the gap from .035" to .045" since you'll have the HEI to fire it. Make sure it's properly tuned and timing is correct. Run it for awhile...maybe 500-1000 miles and the pull the plugs and see how they look. "Reading" plugs is somewhat of an art but it should tell you whether you have the correct heat range.
Do it regularly until you're comfortable you have it correct.
Old Jun 5, 2007 | 07:14 PM
Kalway's Avatar
Kalway
.040" - .045" gaps work fine with HEI
Old Jun 5, 2007 | 09:40 PM
norvalwilhelm's Avatar
norvalwilhelm
I used accel #276 with a .045 gap. They also have the shorty plug #276S
Old Jun 5, 2007 | 09:46 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I agree. You can't go wrong with .045 on an HEI.
Old Jun 6, 2007 | 07:26 AM
dmaaero's Avatar
dmaaero
Running a smaller gap will produce a hotter spark, gap should be determined from the compression of the engine. Higher compression engines like smaller gaps with hotter spark. Changing the gap as little as .005 will result in a 80-100 degree temp change inside the cylinder. Were talking 450 degrees here, opening that gap up .010 will cool off cylinder temp considerable which in return will allow for carbon build up. It"s just a thought but you may want to research the compression of that 427 and gap acordingly.
Old Jun 6, 2007 | 10:42 AM
427basketcase
Thanks for the replies, looks like I had better check the compression of the engine also. It was built when I bought the car and runs really well so I really haven't researched it's internals.
Old Jun 6, 2007 | 01:18 PM
zwede's Avatar
zwede
None of this is correct. Not being a jerk, just stating a fact.
Old Jun 6, 2007 | 04:01 PM
dmaaero's Avatar
dmaaero
It"s not a problem, i was just stating what i read, doesn"t mean its right just because i read it. I would be interested in hearing (why) it"s all incorrect.
To Question about Spark Plugs
