mono spring advice?
Old Jun 7, 2007 | 07:44 PM
jamesd2's Avatar
jamesd2
Default mono spring advice?
Need to update original leaf springs on '73 coupe. Want mono spring. Any advice? Currently running stock '73 350 with headers/sidepipes/Q-jet. Y'all rock. can you imagine if medical doctors who actually cared had a similar forum................................... ......
Old Jun 7, 2007 | 08:21 PM
SIXFOOTER's Avatar
SIXFOOTER
Check out VBP, they got nice stuff. I just did a front mono kit on a members car this weekend, went in no problems and he is happy with it
Old Jun 8, 2007 | 04:48 AM
ltlevil's Avatar
ltlevil
I would definetly go with a fiberglass/composite spring. The weight savings is great an is also a lot easier to handle and install.
ltlevil
Old Jun 8, 2007 | 08:23 AM
redwingvette's Avatar
redwingvette
I just installed one of these and am happy with the ride.
Old Jun 8, 2007 | 09:04 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
VBP 360 lbs/inch seems to work best for most people..
Old Jun 8, 2007 | 10:26 AM
79VetOwner's Avatar
79VetOwner
I have a mono spring from VBP in both front and rear and love them. You can go wrong with the weight savings and improved ride. Not to mention they are adjustable.
The one down side is they are breakable. (I have not broken mine thank god) Some people do warn about them breaking.
Old Jun 8, 2007 | 11:22 AM
kdf1986's Avatar
kdf1986
I think the fiberglass spring is an improvement on the older steel springs. If your not going for originality, then that is the way to go.
I plan on putting them on my cars when I get to that part of the restoration process.
kdf
Old Jun 8, 2007 | 11:27 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Call VB&P and ask their advise on which spring to use (probably 330 or 360). You will want to replace your shocks at the same time. Go with their recommendations & buy their shocks too. Replace the front shocks too.
Old Jun 8, 2007 | 03:28 PM
jamesd2's Avatar
jamesd2
Thanks(all) for the advice. Sounds like VBP is the place to start!
Take 'er easy.
Old Jun 8, 2007 | 04:08 PM
Joe Buck's Avatar
Joe Buck
Yeah, what gives? I plan on going monospring real soon, but I keep hearing about exhaust-pipe heat issues and the random snapping of the mono spring!? Supposedly out of the blue...kinda makes me re-think...
Old Jun 8, 2007 | 04:16 PM
The Spark's Avatar
The Spark
Make sure you have the metal heat shield that goes between the exhaust and the spring. I've had my TRW-style spring for 5 years and haven't had any problems. The ride is much improved.
The shield is just a flat piece of aluminum a little wider than the spring and about 10-12" wide.
Old Jun 9, 2007 | 12:26 AM
ratflinger's Avatar
ratflinger
VB&P Tech Support states that with a minimum of 3" clearance, no heat shield is needed.
Old Jun 9, 2007 | 01:03 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I think the breakage problem is primarily caused by exhaust pipes too close to the spring and, people over-tighten the four bolts of the mounting plate. I can't recall but seems the bolt-torque was about half what the steel spring requires.
Old Jun 9, 2007 | 09:06 AM
Crunch-o-Matic's Avatar
Crunch-o-Matic
I have a 360 VB brand mono spring on my 73 vert. Works great. Make sure you install the heat shield.
Cheers,
Crunch
Old Jun 9, 2007 | 09:45 AM
Stingray1973's Avatar
Stingray1973
Any pics of the heat shield? I've not seen this sold as a part or installed on any cars - to date. Tks - Will
Old Jun 9, 2007 | 04:57 PM
shafrs3's Avatar
shafrs3
The TRW style spring comes with a heat shield, Muskegon brakes sells them.
Shield in this picture is the one between the spring and the spring plate.
Old Jun 9, 2007 | 05:15 PM
JPhil's Avatar
JPhil
I put a dual mount rear spring on my '73 SBC. Love it. Got rid of the sway bar, and it has adjustable stiffness. As I move up the performance ladder, I keep making it stiffer and stiffer. I made heat shields of asbestos cloth sandwiched between two pieces of sheet metal. They mount about 1/4" above the pipes, clamped to the pipes, about 3/4" from the spring, so my pipes are 1" from the spring. Yes it is more work to put in a dual mount, but well worth it if you are going to use the car for anything more than Saturday rides to a car show.
To mono spring advice?
Old Jun 9, 2007 | 08:03 PM
SmokinBBC's Avatar
SmokinBBC
Patti at VBP put me on to this place. Check out their pipe shielding.
http://thermotec.com/products/full/11600/11600.html
Old Jun 10, 2007 | 02:35 PM
jamesd2's Avatar
jamesd2
Do I still need the heat shield if i have headers & sidepipes? I think i already know the answer, but my fear of doing something stupid outweighs the fear of asking a stupid question! Thanks again for all the input/advice on my post..........
Old Jun 10, 2007 | 03:05 PM
SmokinBBC's Avatar
SmokinBBC
No. The heat shield is for when the exhaust pipes go directly under the mono spring to the rear.
