I also went with the dual-mount monospring. I have been pleased with it. I like the idea of adjustability. Too many times I read threads where a guy is asking if 360 would be better, or maybe 420, and then maybe they end up buying another one. I have moved my settings twice. I started out stiff for track set-up, softened it up for warm night cruises, and wish I had jack-bolts for the front springs now too! I am going to have to wrap the dual pipes under the spring now that hot weather is here.
Oh, and the sway bar is outta there! I would only run the bar with hard street tires. The drifting thing, ya know? With sticky tires it just gets scary at corner speeds.
Make sure you have the metal heat shield that goes between the exhaust and the spring. I've had my TRW-style spring for 5 years and haven't had any problems. The ride is much improved.
The shield is just a flat piece of aluminum a little wider than the spring and about 10-12" wide.
i've had mine on for over 15yrs n 80,000mi w/no probs
