New water pump... problem
Old Jun 8, 2007 | 11:39 AM
JustinD's Avatar
JustinD
Default New water pump... problem
I got a new pump from the local autoparts store, it is the stock replacement for my car. I get everything installed and it is not cooling the motor down. Before I changed the pump I didn't have any cooling problems, it was just leaking out of the front of the pump. Could this just be air in the system?
Old Jun 8, 2007 | 11:51 AM
mtwilsonboy's Avatar
mtwilsonboy
I know one time I did the same thing and had problems with amotor over heating. I discovered that when I had my fan off I put it on the wrong way.
Old Jun 8, 2007 | 11:58 AM
JustinD's Avatar
JustinD
Mine has a clutch so it can only really go on one way. I hope that I don't have to tear it all apart again.
Old Jun 8, 2007 | 12:15 PM
piper.gras's Avatar
piper.gras
try taking your thermostat housing off, pull out the stat, and fill the motor with coolant that way. it should ensure that you get coolant into the pump (if that was your problem). replace the thermostat, housing, hoses, and try it again.
big_G's Avatar
big_G
Yes
Old Jun 8, 2007 | 12:19 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I agree that it's probably air in the system.. If that is not the problem, you could do what I did.. I got myself a Pro Comp aluminum high flow water pump (35% more flow) for about $45... In combination with my Griffin Radiator, my temerature hasn't gone above 190 degrees, even on a hot and humid Florida day in stop and go traffic...
The way that I get air out of the system is to take the pressure cap off the radiator and let the car run for a minute or 2.. If there is air in the system, you'll see the fluid level in the radiator drop.. Top it up until it doesn't drop anymore..
Old Jun 8, 2007 | 12:31 PM
68coupe's Avatar
68coupe
air in the system.
Take the cap off, let in run until the thermostat opens. you will see the flowing coolant. then fill if needed. Runnning with cap off will not do any damage.
Thanks,
Joe
Old Jun 8, 2007 | 12:40 PM
...Roger...'s Avatar
...Roger...
Or pull the plug in the top of the pump and fill the pump.Dont do it through the cap and wait for the air to exit,if the pump is full of air and the thermostat holds tight it wont come out before it over heats.If you want to fill through the cap and not trap air then drill a 1/64 hole in the therm. so it will bleed through and not trap air.
Old Jun 8, 2007 | 01:25 PM
JustinD's Avatar
JustinD
I pulled the cap when it was cool and air rushed out. I loosened the plug off the pump and coolant started coming out. So maybe I have air in the block. I'm going to pull the tstat and fill it and drill a hole in it too.
Old Jun 8, 2007 | 01:53 PM
Matt Gruber's Avatar
Matt Gruber
any hole will slow warm up.
chilly in winter
Old Jun 8, 2007 | 02:02 PM
dgruenke's Avatar
dgruenke
Once you fill it that way, seal it back up, and fill it at the radiator. Let the car run until the thermostat opens. You should see the coolant level drop some. Top it off, and close it up.
Old Jun 8, 2007 | 04:48 PM
JustinD's Avatar
JustinD
Ok, I replaced the tstat instead just to be sure it was opening. I ran it with the cap off the radiator. I kept filling it as it went down. I put it all back together and it still gets hot. I've had the coolant drained so many times and never had a problem like this before. Is there a way to check to see if my pump is pumping the coolant well?
Old Jun 8, 2007 | 05:43 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...had a friend replace his water pump from one of those Pep Boys/AutoZone/Advance type auto parts store too and his car didn't cool either. He took the pump apart and found the impeller was spinning freely on the shaft. One more reason why I replace these type parts with brand new A/C Delco parts. Yeah, it might be $80 to $120, but it'll be identical to your original one and fit and perform like it's supposed to.
Old Jun 8, 2007 | 05:52 PM
JustinD's Avatar
JustinD
Well, I hope that is not the case. I guess I had better get ready to pull it off again. For the 4th time in the past week.
Old Jun 8, 2007 | 06:03 PM
...Roger...
Justin with the cap off(be careful)rev the engine and you should see the coolant shoot out of the tubes inside the radiator.
Old Jun 8, 2007 | 06:08 PM
dgruenke's Avatar
dgruenke
This also works better if you lower the coolant level a little bit so that you can see it actually shooting out.
Old Jun 8, 2007 | 06:33 PM
JustinD's Avatar
JustinD
When the level was a little low and I was filling it earlyer I could see it jeting when looking in the radiator. It was not a huge stream but there was one.
To New water pump... problem
Old Jun 8, 2007 | 06:51 PM
Mikes*Corvettes's Avatar
Mikes*Corvettes
But also have your heater set at the hot position,to bleed all the air from the heater matrix also.
Old Jun 8, 2007 | 07:04 PM
JustinD's Avatar
JustinD
Heater is not hooked up. I have the intake and pump caped off where the hoses ran.
Old Jun 8, 2007 | 07:07 PM
JustinD's Avatar
JustinD
Well, I'll be back in a few hours, off to the graduation cerimony.
