69 BB - Different Starters?
Old Jun 11, 2007 | 09:54 AM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
Default 69 BB - Different Starters?
New C3 owner here, and I have a question about the starter. My "new" Vette is a 69 427 with Muncie 4-speed. I'm having starting issues (which sounds pretty common on here), so I'm re-doing all the grounds, and replacing ignition key switch, battery cables and starter.
Problem is with the starter. The one I ordered was apparently correct, and all measurements between the old and new check out except for the "throat" diameter. The old one appears to be 2 5/8" and the new one is 3 1/8". So of course the new one won't fit in the bell-housing?
What do I need to specify in order to get the correct starter; it could be that I have mismatched parts somewhere?
Also, to add a remote cranking switch to the starter, which two connections on the starter do I wire the switch to?
TIA,
Steve
Old Jun 11, 2007 | 06:47 PM
TX427C3's Avatar
TX427C3
No one knows the difference between the two starters?
Guess I'll just swap solenoids and put the old one back in.
Old Jun 11, 2007 | 07:16 PM
Ironcross's Avatar
Ironcross
THE STARTER WITH THE CAST IRON NOSE IS THE CORRECT STARTER
396/427`s use this starter, the other with the aluminum nose is for 350`s and 454`s. ...There is also two switches, a early non metric longer switch and the shorter metric one that normally has only two posts instead of three........
Old Jun 11, 2007 | 07:23 PM
TX427C3's Avatar
TX427C3
Thanks, I appreciate the info. I need to check the part number then - I got the new one from Summit.
Old Jun 11, 2007 | 08:58 PM
Ironcross's Avatar
Ironcross
Not the best place to buy electrical parts either price wise or correct parts.
They don't know electri9cal like we do. I`m amazed they didn`t try to sell you one of those high dollar mini things .
To 69 BB - Different Starters?
