454 motor assembly
Old Jun 11, 2007 | 02:44 PM
eastltd's Avatar
eastltd
Default 454 motor assembly
Hi Guys,
I'll be assembling my motor in the next week of so, depending on final parts arrival and would like your opinions on replacing the crank main bearing and connecting rod bearing bolts. This motor has not been torn down to this level before and the exisitng bolts should only have been torqued up once.
I did order a replacement set of ARP rod bolts for the stock rods but they are a different diameter then the originals and would require rework of the existing rods & caps.
Any thoughts would be appreciated.
Ian
Old Jun 11, 2007 | 06:07 PM
Little Mouse's Avatar
Little Mouse
Send the new bolts back get the right ones, take the new bolts and rods to
the machine shop torque them down check the sizing on the rods.
Old Jun 12, 2007 | 09:09 AM
eastltd's Avatar
eastltd
Thanks for your input Mouse.
What are your thoughts on reusing the main bolts?
Old Jun 12, 2007 | 09:19 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Re-using main bolts is fine. If you really want to step up got to some studs....but unless power is going to be pretty high, no need to.
I agree with previous info on rod bolts.
JIM
To 454 motor assembly
