Is it just me? I've used needle nose pliers several times to remove the door lock **** on my 73. Decided that I would invest in the "Right" tool this go round. Purchased the Door Clip Tool and to my surprise, it didn't work
I have power windows and it appears that this tool is used for the manual window crank. Or is it? I need it for the door lock ****.
Is it just me that can't use a specialty tool correcly or is there something else that works better than a pair of needle nose pliers? Did not see a tool for this in any of the top supplies catelogs.
Let me know if I need to keep my needle nose pliers on duty.
Sometimes a shop rag will catch the clip and pull it off. A small screwdriver will also work if you can see the end of the C clip. I have a tool but sometimes old body shop tricks work.
