Leaking oil BB intake
Old Jun 11, 2007 | 11:42 PM
james.frazita's Avatar
james.frazita
Default Leaking oil BB intake
OK, I have seen some of the threads on fixing oil leaking intake gaskets. On my 1968, 427 GM aluminum intake to an Iron oval port head I am using Fel-Pro 1212. Should I put some (small amount) high temperature sealers around all the ports???? The center open ports around the crossover exhaust heat tube is also filling with oil. Any ideas????
Old Jun 12, 2007 | 12:09 PM
WESCH's Avatar
WESCH
Hi
I used sealant only on all 4 water ports and both crossover walls. I also used the rubber seals, some don't and only use sealant there.
I don't think you need to use selant on the intake air ports.
Günther
Old Jun 12, 2007 | 12:34 PM
S489's Avatar
S489
are you putting any sealer on the intake bolts?
Old Jun 12, 2007 | 04:08 PM
james.frazita
Default Response
Yes, I am using ARP bolts and white sealer.
Old Jun 12, 2007 | 05:21 PM
66427-450's Avatar
66427-450
Sounds good, make sure everything is clean and dry.
May also want to check to ensure all the mating surfaces are parallel...... so many of these old heads/intakes have been milled.
Old Jun 13, 2007 | 01:47 PM
WESCH's Avatar
WESCH
Hi
Not all intake bolts go htrough into the water jacket. I checked this up and only sealed the once that did, I think 4 each only.
Günther
To Leaking oil BB intake
