March pulleys?
Old Jun 13, 2007 | 03:04 PM
HO-alts-Rick's Avatar
HO-alts-Rick
Default March pulleys?
Anyone using the March outward bracket and pulley system? Did you use the saganaw type pump? March is saying they aren't sure if it fits or not, so I figured someone here had tried it and I would ask before I dropped $2000 everything. They say that they know it will work with the remote resivoir type PS pump but I would rather not go that route. Thanks
Old Jun 13, 2007 | 03:34 PM
71rdster's Avatar
71rdster
Who are you talking to? March, Jegs, Summit? March lists a bracket for the saginaw pump, but I can't tell from their web page which bracket comes with the kit you are talking about. Are you looking at the kit on page 7 in this catalog? If so, it looks like it has a saginaw pump in the example.
http://www.marchperf.com/catalog/march_mini_5-07.pdf
Old Jun 13, 2007 | 05:19 PM
PolishMike's Avatar
PolishMike
It is a tight fit, but it does fit. I went with the remote reservoir route, not to bad.
To March pulleys?
