Shifter Problem...
Old Jun 14, 2007 | 07:11 AM
STROKED 66's Avatar
STROKED 66
Default Shifter Problem...
Just out of the trans shop and my shifter will not go into reverse. Shifts into reverse when on the lift when the lockout rod is "pushed-up" over the "hump". Any ideas as to what may be happening here? My 71 LS5 is all stock and I hate to take the easy route and drop in my Hurst that is in ready standby. Thanks in advance for any help.
Old Jun 14, 2007 | 09:44 AM
wombvette's Avatar
wombvette
I dont know that I understand what you are saying, but if the lock rod is not working, just remove it from the shifter. If that dont let it go over to reverse, adjust the rods so it will.
Old Jun 14, 2007 | 10:07 AM
...Roger...'s Avatar
...Roger...
If on the lift you can push up the lockout rod then its just not going high enough.Remove **** and pull out T and lockout rod (like wombvette said), make sure trans will shift to reverse if it will look at T and see why rod is too long.Sometimes it just needs pulled up a little and secured.
Old Jun 14, 2007 | 10:53 AM
STROKED 66's Avatar
STROKED 66
Thought there would be more to it than that... Thanks, I'll give it a try after work.
Old Jun 14, 2007 | 11:10 AM
...Roger...
Try the easiest first If you want just unscew the shift **** a little ans see if that will allow it to go in.
Old Jun 14, 2007 | 08:39 PM
depdep3's Avatar
depdep3
I had a similar problem where I could not get into reverse. I could get into 1, 2, 3, or 4 with no problem. I could not get the shifter far enough to the left so that I could go up into reverse.
Removed the shift know and lock out rod, still the same.
The problem turned out to be some how the transmition was in reverse the whole time and thus was preventing the shifter from moving into the correct position to engage the reverse lever (thus locking it out). I disconnected the reverse linkage from the shifter at the transmition. Then took it out of reverse at the transmition, connected the linkage, and it works perfect ever since. Strange, but true.
Old Jun 14, 2007 | 09:40 PM
...Roger...
Thats a Muncie shifter for you they have no internal failsafes in the shifter.(Hurst does)All the levers can move at anytime.With the Muncie shifter you can get into 2 gears at the same time if the internal trans. lockout is worn.Putting the trans in a forward gear and reverse is a common way of locking the driveshaft to tighten the u-joint bolts.
Old Jun 14, 2007 | 09:43 PM
STROKED 66's Avatar
STROKED 66
Default Shifter Problem (Fixed!)
Popped the ball, spring and L/O lever out, still would not go so I moved the reverse linkage adjustment nuts one complete revolution at a time and (5) turns later was the majic number... She's as smooth as any 36 year old beauty! Thanks for the Tech Assist!
Old Jun 14, 2007 | 09:53 PM
...Roger...
That means they didnt use the alignment tool on the shifter.They sorta guessed so be careful on fast shifts you could get hung in a gear.
To Shifter Problem...
