Unusual sound from engine
Old Jun 15, 2007 | 06:19 PM
Danny456's Avatar
Danny456
Default Unusual sound from engine
While out driving around town i heard an unusual squeal metallic type sound fromm the engine. I quickly drove home and parked in the garage. When it was in nuetral and i took the RPMs up to exactly 1500 the sound came back. it seems like the sound is being produced from the front of the engine. What could it be? I checked all the belts they were tight. Now i need to know where to look next. 73 350 4 speed. edelbrock heads, manifold, cam and carb. Any sugestions are aprreciated.
Danny
Old Jun 15, 2007 | 07:08 PM
TortureTest's Avatar
TortureTest
Alternator ? I would look at things that move at a certain rpm, alternator being one of them....is it a vibraty sound ? You should be able to ascertain that it is or is not inside the engine......just your couple of comments lead me to believe that you suspect it to be outside the engine.
Old Jun 15, 2007 | 07:12 PM
Danny456's Avatar
Danny456
yes it sounds kind of shaky and like metal clanking sort of. Sorry for the poor explantion it is just a very weird sound.
Old Jun 15, 2007 | 07:30 PM
dannyman's Avatar
dannyman
Could be worn bearings from either alternator or water pump. Use stethoscope to listen to bearings or I have also used a long screwdriver as a stethoscope. Pay attention to drive belts, run engine and you should be be able to isolate by sound.
Old Jun 15, 2007 | 07:40 PM
Cory1970's Avatar
Cory1970
I vote water pump.
Old Jun 15, 2007 | 07:42 PM
Danny456's Avatar
Danny456
well i went out and took all the belts off and ran the engine for about 15 - 20 seconds. The sound was still there so that elminates power steering pump, water pump, or alternator. This must mean that it is something internal?
Old Jun 15, 2007 | 10:34 PM
Artsvette73's Avatar
Artsvette73
Exhaust manifold leak?
Old Jun 15, 2007 | 10:40 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Doesn't sound like a whine? Like a throwout bearing? Are you positive its coming from the belt area or could it be coming from the tranny? Sometimes sounds get thrown around a bit.
Old Jun 15, 2007 | 10:44 PM
King Lear's Avatar
King Lear
Veteran
also it could be the crankshaft, I had the same problem and had to put a shim behind it to even it up, my builder just put some washers behind it and it was rubbing on the timing pointer.
Old Jun 16, 2007 | 08:06 AM
dannyman's Avatar
dannyman
Harmonic Balancer?
Windage tray?
Main bearing?
Check harmonic balancer for signs of rubbing. I would get someone to start/stop engine while I continued to troubleshoot.
You should fill in your profile so we know what you have. ie: A/C, stock or electric cooling fan, air pump with original exhaust or headers???
Frustrating to have a noise like this and not find the source! Noise at high RPM leads me to believe that you have something loose and it vibrates at certain resonance. ie: windage tray
Would also check motor mounts.
Old Jun 16, 2007 | 11:51 AM
Blue79's Avatar
Blue79
I once worked on a Chevy engine that had a timing chain so stretched that it wore a hole in the tin timing chain cover. Try putting your stethoscope there to check for unusual noise.
Old Aug 30, 2010 | 11:26 PM
HobbyPoor's Avatar
HobbyPoor
I know this is an old thread...but im having same exact issue...
you ever find a solution/cause
Old Aug 31, 2010 | 04:50 AM
73StreetRace's Avatar
73StreetRace
As nobody said it yet, could it be a camshaft sprocket bolt scratching the timing chain cover ?
Old Aug 31, 2010 | 05:30 AM
gingerbreadman1977's Avatar
gingerbreadman1977
timing marker hitting balancer maybe
Old Aug 31, 2010 | 06:10 AM
mar's Avatar
mar
You can also use a very long screwdriver shaft and carefully place the tip end against components and put your ear on the handle and listen. works great. Just be careful.
Old Aug 31, 2010 | 08:33 AM
James's Avatar
James
Go get a automotive stethascope. About $10.00 at autozone. Put it on and and work around the motor. You will be amazed at what you can here. You can hear the valve train perfect, bearings turning, timing chain noise. I used them to find a noise I had and traced it down to the carb whistling while at idle.
Old Aug 31, 2010 | 09:48 AM
HobbyPoor's Avatar
HobbyPoor
Im gonna check tonight...From what Ive found is that its possibly vaccum being sucked in past one of the crank seals. Im gonna check that tonight.
we will see how it goes....
To Unusual sound from engine
