My front right is sagging and causing tire rub to the fender. 255/60/15
I am pretty sure the spring has collapsed. What is your opinion on springs for the following set-up. Going to be adding a 1 1/4 front sway bar and 7/8 in the rear. The shocks are pretty much stock, KYB's. The rear spring is a stock rebuilt 9 leaf. I have built a 406 for this car and once in awhile do a autocross. Added a Mcleod bellhousing, extra weigh but for safety. With most of the rest of the suspension being stock, I was going to go with 460lb Grand Touring from VBP. Any feedback?
Also wanted to add, the Spreader bar has really gotten tight due to the spring sag. Most likely I will have to remove it, add new springs, align it and replace the spreader bar as normal.
I've got the 460's in the front of my mostly stock 82 and they work just fine. With the big block and other extra weight I think you'll be happier with the heavier springs.
My .02, your mileage may vary.
Bill
Have the 460's and had to cut 3/4 coil (if I remember right) with all the alum parts I have up front- rad, intake, heads, water pump, master cyl, etc
pic below is with the stock springs which where where in horrible shape so replaced when I rebuilt front end, now rides about an 1" lower up front; before I cut the 460's the inner front tires where not touching the ground it was so high
First off, check your A-arm bushings and ball joints. Second, 255s have been known to rub on front of many cars. Are these new??
If it is your springs, any NEW springs will fix the problem. Selecting what rate is up to you and the ride you want. 460 with KYBs will be very firm. 1 1/4" bar will give you a great deal of stability.
I run 550s, cut one coil, with KYB Gas-a-justs, and a 1 1/4'" bar tight. I have sacrificed all creature comforts for handling. You may not want that. At times a Cadillac ride would be nice. Hopefully others will chime in with some other combos.
Last year I replaced my fronts with 460's and used a rear mono spring rated at 330. The grand touring package came with KYB's which are terrible and much worse than the delco's I replaced with them. If I had it to do all over again, I'd get a stiffer rear spring (360 lbs because sometimes I bottm out with the 330"s)) and go with the Bilstein shocks. Whatever you do, DON'T buy the KYB's, they give a very rough ride and don't stop the up-down bounce on rough roads.
I'm replacing my KYB's with Bilsteins next week --- MY KYB's have about 500 miles on them and I can't stand them anymore
