Switch or motor?
Old Jun 17, 2007 | 12:54 PM
Five-spot's Avatar
Five-spot
Default Switch or motor?
OK, here we go again. On a '75 coupe, Which is more likely to be the problem? I only have two of the four speeds on my heater blower, one and three.Should I start by changing the switch or should I get a blower motor and start with the most likely problem?
Old Jun 17, 2007 | 01:17 PM
dannyman's Avatar
dannyman
switch
Old Jun 17, 2007 | 02:13 PM
SIXFOOTER's Avatar
SIXFOOTER
The easiest troubleshooting point is the connector on the resistor pack on the top of the evap box. Check for voltage on the different pins associated with each switch position.
To Switch or motor?
