Rear axle code info needed
Jun 17, 2007 | 03:34 PM
I was trying to find the code on my rear end for my 69 vette and was having some trouble finding it.
I was told to look at the right front side where I did find GM stamped but its really hard to see and I was using a flashlight and a mirrior
Does anyone have a picture of the location so I can get a better idea where to look?
Jun 17, 2007 | 03:37 PM
Axle codes are stamped on the bottom of the differential carrier housing just forward of the cover.
Jun 17, 2007 | 05:08 PM
OK I will check it out
Jun 17, 2007 | 05:35 PM
Yes there are numbers there but very hard to read.
Reading from left to right 0J 2??7 8 E1
Mean anything?
Jun 17, 2007 | 06:14 PM
Fonz69, the only thing I could find was the oj which was a code for a 81 vette which is a 2.87:1 positraction with automatic or a 78 vette which was a 3.70:1 positraction
Jun 17, 2007 | 06:54 PM
guess when I take the body off and go thru it I will have to do it the old fashioned way and rotate and count teeth
2005 ,
axel ,
axle ,
bottom ,
c6 ,
carrier ,
code ,
codes ,
corvette ,
cover ,
differential ,
forward ,
housing ,
performance ,
rear ,
stamped
